Question about Brother LS-2125 Mechanical Sewing Machine
I have a brother ps57 sewing machine
I have forgotton how to thread the sewing machine bobbin only please advise urgently
MY PROBLEM IS NOT WITH LS-2125 MECH SEWING MACHINE
Posted on Jul 06, 2008
Threading the bobbin
hi Sharon.
not sure if this will help you out because its saying its for the, ls 2125i.. but try this step by step link.
How to Thread Brother Ls 2125i Sewing Machine
or this youtube video link.
How To Thread Bobbin on Brother LS 2125 Sewing Machine
this link might be the best one for you to watch.when you go to this one scroll down the page a bit and you will see where you can watch the video,
How to Thread bobbin on the Brother LS 2125 sewing machine
Nov 25, 2017 | Brother Sewing Machines
I have a brother vx1100 sewing machine and I forgot how to combine the bobin thread with the upper thread to start sewing please help
ono secret
just pull the bobbin thread down the slot in the bobbin holder and under the spring plate
leave about 6 " thread loose and put the bobbin and holder back in the machine
use you hand and turn the machine over a few times and the needle thread will pull the bobbin thread up
or use a bit of scrap material and start a short sew
Jan 15, 2017 | Brother Sewing Machines
I have a brother model XL-5500 sewing machine but I do not know how to wind elastic thread onto the bobbin please help me
Generally, elastic thread should be hand-wound onto a bobbin to use in a sewing machine. This allows the elastic thread to be wound without any stretch incorporated before stitching.
Feb 22, 2016 | Brother Sewing Machines
The bobbin on my Brother Xr 34 sewing machine won't catch Please help
try changing the needle
try a different bobbin
try turning the bobbin the opposite direction
make sure the bobbin is inserted correctly into the bobbin case
there could be something wrong with the hook and hook race
and the machine may need some adjustment
Mar 06, 2013 | Sewing Machines
I am trying to sew a baby blanket, but when I start the thread keeps binding up. I am new to sewing and asked a friend, they said it was a bobbin problem so I change it. I started sewing again and problem...
To:
By ladydiane56 on Jul 10, 2011
I am trying to sew a baby blanket, but when I start the thread keeps binding up. I am new to sewing and asked a friend, they said it was a bobbin problem so I change it. I started sewing again and problem still there. Need some advise. Thanks
It sounds like the tension between the top and bottom threads isn't balanced. With the machine threaded, pull both threads towards you and feel if one is tighter than the other and if so, adjust the tension. Top thread adjusts with the tension knob on the front of the machine, bottom thread adjusts where you load the bobbin. Could also be that the bobbin is sitting in the shuttle the wrong way. Have it sitting in the shuttle so that as you look at the open shuttle and pull the thread, the bobbin turns clockwise. Hope this helps.
Jul 10, 2011 | Brother Sewing Machines
I have install the bobbin like the directions say , Everything is assembled right yet the sewing machine needle will not pick up the thread from the bobbin. It has always worked in the past. Please advise
Make sure that you have pulled the thread through the tension spring on the bobbin case and the tension spring in the bobbin case area on the the machine and hold the thread out so that when the needle comes down, as you move the wheel slowly towards you, it will hook it.
Jul 22, 2010 | Brother LS-2125 Mechanical Sewing Machine
Hello, i am having problems! I was sewing fine and then all of a sudden i started having loopies and bunching coming from my bobbin. I have tried a new bobbin, there isnt any thread in the area, i have...
You have done everything you can do.
If you thread your machine with the presser foot up (this allows the thread to seat into the tension control), then it may be the machine needs to go into the shop for service.
When the tension cannot control the thread, the bobbin thread cannot knit with the top thread - it looks like a bobbin issue but is due to lack of control of the top thread.
Try one more time, threading with the foot up and if the problem continues.........take a sample of the stitching as this may well be a timing issue.
Be sure to go to a Brother dealer so you do not void any warranty coverage (timing would only be covered during the first year).
Mar 28, 2010 | Brother SE-270D Computerized Sewing...
Brother XL-5130 Sewing Machine
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Feed the thread thru one of the holes (the hole that will be on top) going from the middle of the bobbin thru to top. pull up about 2 inches, push the bobbin over to start winding and before pressing the foot, hold the 2inch piece sticking up. HOLD TIGHT. after the thread is wound about 25 times, stop winding and snip the 2inch piece level with the top of the bobbin. Finish winding.
Apr 13, 2009 | Brother XL-5130 Mechanical Sewing Machine
Corect threading needle for sewing on brother lx3125
please follow the instruction
1. raise needle to its hieghest position
2. remove hand hole cover plate
3. remove bobbin case from shuttle, pull open latch of bobbin case
4. pull bobbin case straight out of shuttle
5 insert bobbin into bobbin case making sure thread is coming from bobbin.
6. pull thread through slot
7. pull thread under tension spring
8. holding latch open position case into shuttle, and release latch. case should lock into place when latch is released
happy sewing.
regards please rated me.. thanks
Mar 31, 2009 | Brother Sewing Machines
Bobbin holder keeps catchin thread
Try re-threading, make sure the presser lifer is up so the tension discs are open and the thread will go into them. It sounds like you may have missed either the upper tension discs or the take up lever.
A drop of oil on the hook wouldn't hurt if you haven't oiled in awhile.
good luck!
Jan 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
170 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
