Question about Fire Magic Regal II (LP) 15-S1S1P-A All-in-One Grill / Smoker
Heat Stain How do I clean the heat stain off the back of the top lid?
    Scholar:
  • 145 Answers
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Posted on Aug 24, 2009
I mistakenly sprayed oven with cleaner just before self cleaning , now it's got a stain which I can't remove. Any answers.
and it probably wont be between the high heat and the chemical s you either bleached out or removed the protective covering / causing your stain
Jun 13, 2017 | Ovens
Which one has more heat resistant: Granite or Silestone? Explain?
Planning to refurbish your kitchen, Now-a-days, a wide range of choices for kitchen countertops are available in the market, which make you to choose the perfect one. In case if you are looking to select granite or Silestone for your kitchen worktops. Then, as per my knowledge both are popular choices, but he Granite is a very durable natural stone with a high aesthetic value. It is heat and scratch resistant but also porous and therefore possible to stain; it needs periodic maintenance. Where as the quartz used in countertops and flooring is a man-made combination of resins and crushed quartz. The resulting surface is non-porous, meaning it is more stain resistant than granite and requires less maintenance overall. For further detail explore at: Black White Granite Kitchen Worktops in Surrey Essex MKW Surfaces
Feb 29, 2016 | Green Bean Cleaning Products Commercial...
1991 Ford Thunderbird leaving black stain on ground when I start my engine
Stain from the exhaust pipe, or liquid leaking? Exhaust pipe powdery stain from carbon buildup in engine. Either runs rough, needs plugs, or hasn't been driven fast enough to heat the engine. Insufficient information, check engine light on? Runs good? Other than stain, what else going on.
Jan 21, 2016 | Ford Cars & Trucks
What can I use to remove a stain of SOYSAUCE in a carpet?
Carpet
1. Mix one tablespoon of liquid hand dishwashing detergent with two cups of warm water.
2. Using a clean white cloth, sponge the stain with the detergent solution.
3. Blot until the liquid is absorbed.
4. If the stain remains, mix one tablespoon of ammonia (Caution: Never mix chlorine bleach and ammonia - the resulting fumes are hazardous) with 1/2 cup of water.
5. Sponge the stain with the ammonia solution.
6. Blot until the liquid is absorbed.
7. Sponge with cold water and blot dry.
Nov 21, 2014 | Heating & Cooling
Blood stain on my pants
Blood stains are considered to be organic stains because they contain proteins. Protein is the building block for nearly every living thing on the planet, but it's also what makes removing a blood stain difficult. Proteins react chemically and bind to one another; typically, you can't remove blood stains completely using traditional stain lifting methods. To remove blood stains from clothing, avoid exposing the garment to heat or hot water. Opt for using a natural enzyme to lift the stain instead of using bleach, or other chemical stain lifters.
Apr 11, 2013 | Health & Beauty
How do I get the white heat stain off of my tempered glass, air tight gas furnace?
You'll need to remove the glass from the fireplace, but not before turning off the pilot light. Then mix a 50/50 solution of White Vinegar & Water. Using a sponge soaked in the solution and partially wrung out, clean the glass on both sides using the solution & sponge. Reapply as necessary until the glass is clean. Dry thoroughly with paper towels, before reinstalling the glass.
The heat stain is not really a heat stain. It's left over residue, from when someone used commercial glass cleaner to clean the glass. The white stain is from the ammonia in the cleaner.
Hope this helps you and thanks for choosing FixYa.
Sep 16, 2011 | Heating & Cooling
I am looking at buying a Wagner Max HLVP sprayer. The jobs are staining a modest stretch of fencng and a larger staining project of an overhead pagoda-type structure. Is this a good choice or would you...
I was a painting contractor for last 10 years of my work career.
If you are using HVLC cup gun, you will have to select correct tip,
You will need to thin the latex 50-50 with water, and keep paint strained to keep out all clogging.
If the tip is not reversible, then expect disassemble each time clog happens.
And you will be continually re-filling the cup.
And then if the surface is rough, the spray won't flow into the holes.
You have a mess coming your way.
Painting a fence: A roller is the only way to paint/stain rough surface.
Buy big hairy 1" roller cover from Sherwin Williams. Don't get the cheapo 1/4" thick roller cover because it doesn't hold any paint. The big roller holds a big volume of paint.
Now if fence is rough, like cedar, you need to thin the stain.
About 1.5 gallon water per 5 of stain ... and suddenly you have 6-1/2 gallons of stain which means you bought too many gallons of stain.
So don't overbuy the stain. And pick up 2 plastic bucket for mixing.
Empty gallon of stain into mixing bucket > put water into empty gallon > put lid on gallon and shake up > pour water into mixing bucket with stain > to mix: pour mixing bucket of stain back and forth between other mixing bucket until stain is mixed. Do this work on the grass where it won't run out onto concrete surface.
Put roller and frame on a wood pole that you took off the push broom. Now roll that stain onto every surface the roller can touch. Think of it like picking up quarters. If it was money, could you get the roller on that spot >> the answer is yes. Don't try to smooth it out and make pretty. Throw the stain on any way the roller can turn. Customers used to call that 'slapping it on' and I used to say, 'that's how it works, lady.'
Use a piece of masonite at the bottom. If you get stain on anything, wash it off immediately and use a wire brush on concrete surface or towel on smooth surface.
Wait for a day, because stain looks 100% better next day. And then go back with a brush and hit the spots you couldn't get with the roller. It will be faster and cheaper and fewer headaches than trying to spray latex stain with a HVLP cup gun.
To clean the roller: Leave it on the roller frame and wood stick. Turn on water hose and get the roller spinning until it's clean. Do this away from everything you don't want stain on.
Dec 13, 2010 | Garden
Broiler not working and stains around gas burners
use a stain remover like hapic, or gbc and the stain will go off.
Aug 03, 2009 | Siemens HD2515U Stainless Steel Dual Fuel...
Kenmore Over the Range Microwave
If you think the window is stained, you ought to see the rest of the inside! Wife is probably right. (wink, wink, nod, nod)
Actually, you can take the cover off, remove the front panel without much effort and clean everything and get a lot more life out of it. Microwaves usually die because of heat related problems caused by buildup of yuck on the guts.
Hope Ya Make your Wife Happy!
Jan 24, 2008 | Microwave Ovens
Detergent stains on the finish of the washer and dryer
Try one or all of the cleaners listed below to remove the stain. Hope this helps you.
  • Oxygen bleach
  • Rubbing alcohol
  • White vinegar
  • Baking soda
  • Hydrogen peroxide
  • Acetone
  • Paint thinner
Steps to Remove the Stain:
  1. Laundry soap dyes are usually more difficult to remove than other colors.² However, oxygen bleach, such as Oxi-Clean, can sometimes clean away even the red stains. Sprinkle the powder on a damp sponge and scrub away the stain.
  2. Soak a cotton ball with rubbing alcohol and wipe away the detergent stain. If the stain is not immediately lifted, allow the alcohol to soak for several minutes.
  3. Vinegar is effective on many kinds of stains. Make a solution of one part vinegar in two parts water and sponge the vinegar onto the stain.
  4. Baking soda can be effective for removing detergents from appliance surfaces. Sprinkle baking soda on a damp sponge and clean the stain until removed.
  5. Combine equal parts of 3% hydrogen peroxide with water and sponge the stain with the solution.
  6. Soak a cloth with acetone nail polish remover and use it to wipe off the stain. If the stain does not wipe off right away, it may help to lay the cloth over the stain to soak for a few minutes.
  7. As a last resort, wipe paint thinner on the stain. Paint thinner can remove most dye stains. However, you may want to test this on a small, hidden area first to be sure the paint thinner won't damage the lacquer on the appliance or cause any other adverse effects.
  8. Once you have removed the stain, wash the area with soapy water to remove any residue from the cleaning solution.
Jan 06, 2018 | Washing Machines
Fire Magic Regal II (LP) 15-S1S1P-A All-in-One Grill / Smoker Logo
101 people viewed this question
Top Fire Magic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
