Samsung television sound fading, now no sound at all
I personally think that the speakers connections are broken. when i turn on the tv i have no sound
  • Anonymous Aug 09, 2008
    My Samsung TV had sound one day and the next day there is none at all. I get no sound thru' the TV speakers nor thru' the A/V receiver. Any ideas?
  • mega111 Dec 02, 2008
    The sound on my Sumsung Plano starts normal and with in a short but not consistant amount of time it fades away almost to nothing?? Has anyone else had this drama?
My Samsung tv has sound and then it fades away
Posted on Aug 15, 2008
Toshiba tv speakers broken
You probably have a bad solder connection that has completely opened up...Or if you have a flat screen TV you will need to change the main board... Just get the model number and go to HERE for availability and part search. The main board has the audio circuits.
Nov 25, 2013 | Televison & Video
Hitachi 51F710E has no sound
The audio portion of the main board is failing. You can get a replacement here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 07, 2017 | Hitachi 51F710 Rear Projection Television
Problems with internal speakers of the Samsung LN32A450 TV
Problems with internal speakers of the Samsung tv Can I buy replacement speakers and install it myself.
Apr 30, 2010 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Receiver fading in and out.
I want to think about this for awhile but first I want to caution you to NEVER turn the volume all the way up and then place your ears near the speakers for diagnosis of an unknown problem. If you inadvertently affect it to come back you can kiss your speakers (and maybe your ears) goodbye.
I'd agree that it is none of your hardware if it affects all inputs, two receivers and multiple speakers.
This sounds like a good one.
The simplest source to use for further trouble-shooting would be FM as it has no external connections, and it's vanilla stereo. Keep It Simple.
"Power bars"? Do you mean like a power strip with multiple outlets and maybe some kind of surge protection? Pare the system down to its most basic form - receiver, front speakers, one power source direct from the wall. What happens? Add components and complexity until the problem returns. Good luck.
Jan 22, 2010 | Audio Players & Recorders
Tried to connect to samsung lcd no sound
Plug the green lead on the speakers into the headphone socket on the television. You may need to go into the menu to turn up the headphone output. Turn it to 70% on the TV, then use the volume control on the speakers
Jan 10, 2010 | Logitech X-230 Computer Speakers
I have a plasma Samsung with picture but no sound
Internal sound board/amp is probably bad. But make sure that the speakers were not turned off in the sound settings menu for the television. You could try hooking up and external reciever to the audio output jacks of the TV and see if you get any audio from there. If you do at least you can still get sound from your tv...even though it is not from the internal speakers.
Sep 26, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Sound fading away
I would not think the speakers are defective but rather faulty capacitors in the power supply circuitry if the TV works good for some time.
Jun 20, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
Philips 32PT71B1 TV sound problem
it might be due to speaker. if it is ok then check for 1 loose connection in sound section. 2 speaker wire loose. 3 any capacitor in sound section might be faulty. 4 check supply to sound section 5 loose connector in sound section. 6 sound ic might be defective. if not tech.person take help from tv tech. hope this will help. good luck.
Oct 01, 2007 | Televison & Video
High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Feb 25, 2007 | Samsung TXN3071WHF 30" TV
Televison & Video Logo
494 people viewed this question
Top Televison & Video Experts
