Question about Orion STV2763 27" TV
TV goes on and off.
I have an Orion STV2750 27" TV. Manufacture date March 2001. It was working fine, then just shut off. After about 10/15 minutes it will turn back on. Stays on about 5 minutes,then shuts off again. Is this an easy, inexpensive fix? Can you help me with this?
    Brigadier General:
  • 6,966 Answers
Based on your description, it would appear to be a case of cold solder issue (most likely) or heat related (just a possibility) or both interrelated.
Repairs wold require the application of a low wattage soldering iron at the determine cold solder joints. They can be determined by checking for those that are dull grayish in color as compared to the regular/good bright silvery. Should you not be able to determine the exact cold solder joint, a shotgun approach would also do. This is re-soldering most of the major joints with particular attention to the power devices such as the bridge diode, regulator IC, chopper transformer, capacitors in the power supply; the vertical IC; the flyback transformer pins and the Horizontal out. Often, the major joints would be bigger than the regular solder joints.
The above of course requires familiarity with electronic circuitry and components, use of a soldering iron and perhaps even a DVM. Should you be uncomfortable, then perhaps your best bet wold be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back on the model number how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Additional information:
cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the TV turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have posted on then off then on, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
This might be of help to you.
Posted on Jul 06, 2008
Vision battery date code
ALL VISION BATTERY MODELS
Date code stamped on top of battery container
X1 X2 X3 X4
Where X1 denotes year of manufacture A = 2001 B = 2002 etc.
X2 denotes month of manufacture A = January B = February etc.
X3 X4 denotes date of month of manufacture
Eg AH27 = battery manufacturing date 27th August, 2001.
Dec 12, 2013 | Exide Chloride Power Station (EXP2000) UPS...
Ineed the codes for my radioshack universal remote cat.no.15-302 my tv is an Emerson model EWF2004A date of manufacture is March 2005
These are the setup codes for Emerson Brand TVs with Radioshak 3 in one remote control. 039, 177, 178, 179,180, 185, 236, 280,282, 463,
Jan 14, 2013 | Radio Shack 3 in 1 Universal Remote
How do you get rid of Test that appears on the screen in red
It depends upon the date of manufacture for Hotpoint (Indesit) washers. The date should be on the panel probably at the back in the most handy position, sorry!
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to normal
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
Hopefully one of these should clear it ;-0)
Good luck,
John C
Mar 31, 2011 | Hotpoint Aquarius WF210 Front Load Washer
I need to know if model TV 1326 is digital or analog.
If you mean the Orion TV1326, it most likely has an analog tuner. However, you can usually find a panel on the back of the tv with the serial number and the date it was built. Small TVs weren't required to have a digital tuner until March 2007. (There was a staggered rollout and 13" TVs were in the last group for the transition.)
I hope this helps.
Dec 17, 2010 | Televison & Video
Whirlpool washer age
Your washer was manufactured in March of 1993. The manufacture date is determined by the Serial Number. The second letter "C" represents the YEAR of manufacture. The first two numbers "14" represent the WEEK it was manufactured. The 14th week puts the manufacturing in late March. I hope this helps you.
Sep 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
What year is the mitsubishi ws-65809?
My model is the same and on the sticker at the rear of the TV w/ valuable info. states 2001 as the year of manufacturing.
Feb 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
How do I decipher the SN on a Motorola DSR922 receiver.
The DSR922 was made from 2001-2007. No more being made from motorola ;-(
The seventh digit from the left is the date code.
So a 4 in that place means manufacture date of 2004.
Jan 29, 2009 | Arris DSR922
IBook G3 900mhz 14" lcd
The date and time are held by the battery so I would guess the battery is going dead or is. Try keeping it plugged in and shut it down for a few then reboot. If the time and date stay good guess the battery is dead. Also make sure you get the power management firmware update from apple. hope it helps
Apr 18, 2008 | Apple iBook G3 Mac Notebook
ORION TV 1926A
lost the remote?... try a different universal remote. i have a orion 27" but i think it has a menu button on the front of the set. im at work.. when i get home ill check and repost....if you dont want to buy another universal.. barrow a friends and give it a try... sometimes the manufacture puts updated CODE's for the remote on the website.. might check that as well. good luck.. more to come.
Jan 22, 2008 | Orion1934 19" TV
Orion STV2763 27" TV Logo
101 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
