Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1200sporty bike backfires dies under load,wont even crank until 1 hour later,then restartes idles fine,replaced battery,no change
  • scohung Jul 06, 2008
    could it be modulator
    Brigadier General:
  • 6,966 Answers
Hi
It would appear that you have two (2) issues:
1. wont even crank - Due to the massive current required by the starter a component is installed between the starter button and the starter. This component then switches the battery to the starter motor. In cars this is the starting solenoid, in most bikes, this is the starter relay. Normally in the starter relay there would be 2 big terminals for the battery and the starter motor cables with 2 smaller wires for the starter switch and ground. Try this - try pushing the start button with the headlights on, if the headlight dims considerably, then the starting relay is good and the motor is bad; on the other hand if the headlight dims just slightly or not at all, it is the starting relay (the one with the clicking sound). I was made to understand that there was a recall order due to starter relay and/or 30 amps breakers.
On the other hand, most starter motor problems could be:
1. the bearings/bushings at the ends of the armature;
2. carbon brushes;
3. commutator segments (the multiple small copper plates that the brush contacts with).
However, it may be to your advantage to simply replace the motor should it be deemed defective, difficult to secure parts or not economically reasonable to go down component level repair.
2. backfires dies under load - There are 2 major requirement for a gasoline engine to run, fuel and ignition. Backfiring is normally indicative of poor fuel to air mixture (most likely) and/or slightly off ignition firing (just a possibility). Areas to check are you air filter, carbs, plugs, intake manifold, seals/locks.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 06, 2008
  • Louie  Role
    Louie Role Jul 06, 2008
    I am not familiar with a "modulator"
I have a 2003 Harley Davidson 1200 sportster,
Cab or injected ?
If carb looks like an leak at the Oring manifold .Try to start and spray any carb cleaner to the manifold close to the cylinder ,.any change on idle would be an air leak!
Oct 06, 2014 | Harley Davidson Motorcycles
Sometimes while riding the bike, it stalls after driving for sometime and then experienced hard start until it won't start again. Had battery checked and it was drained. Replaced with a new battery but...
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging.
3. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for drop in aprerage then get out your test light and track down the short in that circuit.
3. Make sure all connections are clean and tight especially the negative cable at "BOTH" ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v while cranking replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor.
17. For a free wiring diagram please visit the website below. Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
Sep 18, 2012 | Harley Davidson XL 1200 S Sportster Sport...
Vapor locks
It could be a vapor lock but not likely. Since the introduction of fuel injection vapor lock has been eliminated.
You need to figure out if you are loosing fuel pressure or spark when it will not start back up. Could be a fuel pump relay or ignition module among other things. Even a problem with the vent for the gas tank.
Jul 27, 2012 | 1990 Ford Econoline
Relaced coil, ignition module, starter relay bike shuts down when hot and won't start
Replace the cam pickup in the nose cone on the right side of the motor. Due to heat cycles over time the epoxy melts and the wires fall out of the pickup. Pretty easy job to do, but you will have to reset the timing on the bike when you are done.
Jun 30, 2012 | Harley Davidson FLSTC Heritage Classic...
I have 97 camaro it starts and drive fine but when i shut it off it wont start back up until it sits for a few hours?
We had a problem like this in our 97 Camaro with the V6. It would run fine until my wife went somewhere with it, parked it and then wouldn't restart. When it would sit for about an hour then it would start again. It turned out to be the crank position sensor, when the electronic part of it got hot enough it couldn't sense correctly and tell the computer how to time the spark. All it would do is crank without firing. So once we had that sensor replaced it ran good again. Good luck I hope this helps! I'm on to the next problem it's having, an occasional battery drain and a radio and electric windows that die when they want to and come back later. BuzzieTN
Sep 16, 2010 | 1997 Chevrolet Camaro
2002 Big Bear 400. Dies after a few seconds upon startup
sounds to me the valves are not properly adjusted,..like their to tight,...i had run into this in a japanese car once,...check it out and let me know,.....cracklin joe
Jan 10, 2010 | 2002 Yamaha SR 400
Car dies when it heats up and won't crank back up until cooled
normally a speed control sensor can solve this problem, but also check the crank senson.
Aug 24, 2009 | 1993 Buick Skylark
Bike runs until the battery dies
Rectifier and/or stator, could be the problem. Check the amperage out put with an amp meter at idle and at 3000 RPM to determine. Troubleshoot all electrical terminals, disconnect, clean, and apply a small amount of Di Electric grease to contacts.
Corrosion causes a lot of problems and is common on bikes after a few years. The main ground wire from the battery to where it connects to the frame is important also. I have found this heavily corroded on a lot of bikes over 10 years old.
Good luck, hope this helps.
Mar 08, 2009 | 1995 Suzuki VS 800 Intruder
Lands Phones Logo
273 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
