Question about Protron PLTV-37 37 in. LCD Television
Hd tv My video for HDMI cable stooped working. I have tested the cable and PS3 on another tv and they work fine. The RC and composite inputs work fine. Any ideas of what is wrong? Prtron 37" is around 18 months old. Thank you
My HDMI has stopped working. I have had a technician from Dish network out to my house 3 times and they have replaced the receiver and the HDMI cable and were unable to get the set to work all I get is a blue screen and a message which reads no signal. I also cannot use mt set using 3 rca cables connected to the component input when set to 1080 I keep intermittenly get a black screen then a blue screeen and sometimes a no signal message. I have to watch the tv set to 720 on component 2 and it is the most stable in that setting. Please send help
Posted on Jul 28, 2008
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
My ps3 wont work with my hd/mi cable, i get a blank screen, but it does work with the rca jacks?
What you need to do is connect it from both the red/white/yellow cable and your HDMI. Go to your video input on your TV to where you can see the display. Go to settings - Display settings, and switch your input display from composite to HDMI. Your screen will go blank. Once blank, turn your TV to your HDMI input and when you see the picture, save settings and completely unplug the composite cable. You should be good to go.
If this helps, please give me a 4thumbs up!
Respectfully,
Don
Jul 06, 2010 | Sony Playstation 3 (PS3) Console
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Apr 03, 2009 | Sharp Televison & Video
Cannot get my HDMI cable linked from my ps3 2 my hd tv
Try video settings on the playstation 3. Adjust it to reflect hdmi.
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
Resolution problems/ Game problems
Well it might be becuase your ps3 is european. Im no expert on the matter, but when i bought an hdmi cable and hooked it up to my hd compatible tv, i switched to the hd input (which happened to be input4 on my tv) and a message popped up saying that the ps3 has detected hd output, would you like to change settings? and it did it automatically after i hit yes.
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Protron PLTV-37 37 in. LCD Television Logo
369 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
