My Father had this stereo system. He pre-set radio stations. I can not figure out how to unset them so I can tune into other radio stations. I do not have the manual. Thank You, Lori
Thank you. I was able to find the manual on line and it seems that I need to have the remote to adjust problem. Will call Panasonic parts to find out how much it will cost. Have a nice day. Lh1953
If radio has save button then tune your station push save button then push a number on preset you want it saved to. The radio automatticlly stores the strongest station in your area.
Select the AM or FM wave band. Tune the radio to a station then press and hold down the 1 or 2 or 3 pre tune station button until it beeps. Then this radio station is then set to which pre tune button you have selected. Repeat to set the buttons for other radio stations.
hi, there is no auto presettingavailable. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER". 2. Press the FM/AM button to select a band. 3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it, 4 .Press the MEMORY button.( on remote) 5. Within 5 seconds, select a preset channel to store the station using the PRESET buttons of the remote control unit. 6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listeningpreset ed station ,Press the PRESET button repeatedly until the desired preset station is found. ok
When you preset the station, you usually have to press and hold the number you want to set it to until the stereo set makes a noise signifying it has set the channel.
Hope this helps :D
Anymore questions, just ask.
Station Pre Set:
You can save 4 pre sets on this radio (1-4) tune the radio to the station you want to save then PUSH and HOLD one of the pre set butons until the sound returns, the station is saved to that pre set. Repeat for the 3 presets.
Clock:
Hour: Push and hold the CLK button and at the same time push the SEEK button to adjust. < decrease hours > increase hours.
Minute: Push and hold the CLK button and at the same time push the TUNE button the adjust. < decrease minutes > increase minutes.
When you find a frequency that you want to store in memory, press one of pre- set tuning buttons 1through 6 and hold until the preset number stops flashing. The number you have pressed will flash in the preset number indicator and then remain lit. The selected radio station frequency has been stored in memory. The next time you press the same preset tun- ing button the radio station frequency is re- called from memory.
On the front of the system, press and hold Clock button until the hour flashes. Then press the Digital tuning arrows for up or down. Watch the display for AM or PM. Stop on your hour. Press and hold the Clock button again til the minutes flash. Press the Digital Tuning arrows again for up or down. Immediately press Program Set button under the Digital Tuning arrows to set the program in. If you do not press Prog Set soon enough, you will have to do the whole thing all over.
