Back to:
Tags:
ASUS P5N-E SLI Motherboard
ASUS P5N-E SLI
posted by tar espn on Jul 06, 2008
Newly built system and can't even get to POST!
No beaps!
(2) Crucial 1G RAM
(1) NVIDIA 8500GT
INTEL 7700 DUO 2.53 MHz
Removed RAM and installed 1 stick other brand. No POST!
Removed Video card.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 06, 2008
Not Rated (0)
waj27
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Try RAM with a different speed. My 800 mhz RAM didn't work until I installed 533 mhz RAM and adjusted to 800 mhz in BIOS. Newly built PC, default must be set as 533 mhz because I reset the CMOS and still couldn't POST to BIOS. Only taking out all RAM gave me any sort of audible error code. Luckily I found some 533 RAM before I RMA'd the board.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on ASUS P5N-E SLI:
I don't want to Accept this solution
Solution #2
posted on Jul 06, 2008
Not Rated (0)
antiochpc
Rank:Guru Guru
Rating: 87%, 328 votes
Check the BIOS jumper. Some of these boards ship with the bios jumper in the clear position. Change it from where it is now to the other setting and see if that helps you.
Thank You!
Can you Help with these Motherboards problems?
I have this motherboard and i want to buy me the processor...
Motherboards
hey i need help with my problem that im haveing with my...
ok just to clarify....my pc is built like this 1 asus...
My pc fails to go to "sleep mode". It reboots...
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
