Question about Motorola Mobility V325 Cellular Phone
Battery charger when i plug in the battery charger the display window on the phone says unauthorized charger the charger will not charge battery
  • Anonymous Dec 20, 2008
    Every Motorola phone I have eventually does this, and it is not yet fixable, the phone is toast, forget the Motorola name until they give a solution for this problem.
The same thing happened to me, and first I tried a new charger....when that didn't work, I took my phone to Verizon, and they gave me a fully charged battery...that didn't work either. I still go the "unauthorized charger" message. I was then told that the v325 had older software on it, and that I might need to take it to a Circut City or someplace like that and they could do the software upgrade for me? I haven't taken it yet, but will post if that helps.
Posted on Oct 09, 2008
    Novelist:
  • 137 Answers
I'm not sure what the problem is with your phone, but this happened to me with another Motorola phone and it turned out to be a battery problem. You can try another charger, which might work for some time before you get the same result, but I believe you will need to replace the battery. You can try calling Motorola and checking to see if they will give you a discount on another battery. I've had several Motorola phones give me this same message and most of the time it was only infrequently and resetting the phone and reinserting the charger worked, but if it persists, try the battery.
Posted on Oct 07, 2008
I have a motorola crush and my charger worked fine but now when i plug it in it says unauthorized charger
sometimes any motorola phone will give you this message. The phone will still charge but it has to be powered down to charge. Sometimes turning it off, plugging in, and then powering on will help reset the phone.
Jun 28, 2010 | Motorola Mobility BT50 Cellphone Battery
Plugged my charger into my phone and it says unauthorized charger. It has worked fine until now.
That happens because of dirt, debris or moisture in the charging/USB Port, use a can of compressed air (Duster) to clean out the connection and try it again, also remove and replace your battery in your phone to initiate a Soft Reset to your phone.
Jun 13, 2010 | Motorola Mobility Hint QA30 Cell Phone
Unauthorized charger
HimoronI
Could be you have a battery issue.
Mark
Motorola Support
Dec 26, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Motorola v325 won't charge after using phillips universal charger
Sometimes a bad charger can send a high voltage charge to the phone and fry the charging port on the phone. That is why a lot of the car chargers today have a fuse on them now. So that it will blow the fuse on the charger, instead of frying your phone's charger spot.
Dec 01, 2009 | Verizon Communications Motorola V325i...
I keep getting a message of unauthorized charger when I plug in m
IF THIS CHARGER IS AN AFTERMARKET IT MAY NOT WORK WITH THE PHONE
Aug 10, 2009 | Motorola Lands Phones
change your battery and charger. tnx
Jul 28, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Unauthorized charger everytime i plug it in.
There may be a problem with your charger output. Do you have another charger you could try?
A temporary workaround is to reboot the phone with the charger still attached. It should now say "Authorized" and start charging.
Jul 25, 2009 | Motorola Mobility W385 Cellular Phone
My motorola w755 stopped charging
Is it saying "Charging" when plugged in?
Could be the wall charger.
Mar 12, 2009 | Motorola Mobility MOTO W755 Cellular Phone
"Unauthorized Charger"
you can try to clean the charger port (but first make sure its not bent, or broken - the pins are really tiny and hard to see, so make sure)
But try cleaning the charge port on the phone and the charger with denatured (rubbing) alcohol, and a toothbrush -
Just make sure not to plug it in when you do this!
and clean both the charger and phone, make sure neither are bent
lastly, try a new charger!
NGK
Dec 22, 2008 | Motorola Mobility RAZR V3
Charging
Its the battery.
You can try putting the battery in the freezer for 8 hours, then leave it at room temperature for 24 to see if it can be saved.
Best of Luck.
Oct 13, 2007 | Motorola Mobility RAZR V3
Motorola Mobility V325 Cellular Phone Logo
559 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
