Question about Danby Dishwashers
Water is not pumping through spray arm - Danby Dishwashers
  • 95 Answers
Check for water coming into the arm, first. A lot of times it can be excess food debris recycling in the wash cycle, getting caught in the spray holes
Posted on Jul 06, 2008
Why is the top spray arm not turning
All of the water coming to the upper spray arm comes through the feed tube. If the feed tube is blocked or the probe flapper is hung open, water will not flow properly to the upper spray arm. Be sure that when you push in the upper rack the manifold probe is in position in the feed tube. Try adding more water in the tub to see if the upper spray arm starts rotating. Other possibilities; low water charge, cracked spray arm & poor wash pump performance.
Jul 28, 2016 | Dishwashers
Motor runs but
Do you have a print manual for this unit?
Aug 05, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
The spray arms aren't spinning, any ideas?
The main water pump sounds to be defective, not supplying enough water pressure to turn the spraybars.
Nov 05, 2015 | LG Dishwashers
Aeg oko favorit 50500w water not coming in through spray arms
There are several reasons if spray arms doesn't spray water. First you need to check efficiency of circulation pump. If it works, then should check the turbine of circulation pump. Sometimes turbine blades can be broken and the pump does not produce enough pressure to turn the spray arms. Be sure to check that the filter is not clogged which can also causes same problem. Finally, check that the nozzles of spray arms are not clogged.
So, could be:
- motor circulation pump
- circulation pump
- filter
- spray arms
- electronic or power board
Dado
Jul 12, 2014 | AEG Dishwashers
Arms are sometimes not turning (intermittent) problem ?
Hi Gaetan, I am happy to assist you. Will the spray arm rotate freely or is it damaged? If so, you might have to remove and replace the spray arm assemblies. Another possibility may be that not enough water is being pumped to the spray arm. The top spray arm typically starts to function when the unit is in rinse or wash cycle. If for some reason the top rack is not getting clean, there is a possibility that it is not working properly. The top spray arm is either blocked by pots/pans or not enough water pressure is being pump meaning that the flow of water is not making it to the upper spray arm. If you tap the delivery tube that feeds this nozzle and the water pressure jumps immediately, then the problem may lie with a faulty pump or impeller. Should all basic troubleshooting measures fail contact a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
Aug 13, 2013 | Frigidaire FPHD2491KF Dishwasher
Top rack does not wash dishes.
Possible causes of spray arm inefficiency:
Loading large or tall items in the lower basket which stops the arm revolving.
Upper spray arm split along seam.
Upper spray arm blocked.
Under dosing of powder causing foam and reducing upper spray arm water pressure.
Blocked strainers reducing water to circulating pump, therefore reducing upper spray arm water pressure.
inefficient wash motor impellor (faulty)
Dec 21, 2009 | Kenmore Dishwashers
Waterpump does not pump water through arms
what gets the water in the spray arms
Aug 19, 2009 | Whirlpool Dishwashers
Dishwasher
Plugged filter or spray arms .
Sep 30, 2017 | Dishwashers
Danby DDW396 Spray Arm
The spray arm is controlled by the force of the water. There is no motor running the spray arm. If water is not getting to the spray arm, then it won't spin. It may be plugged with detergent etc. Just a note re. detergent. You shouldn't use hard or caked detergents.
Dec 03, 2007 | Danby 22 in. DDW396 Free-standing...
Sprinklers not turning
if no water out of spray arms there can be two causes spray arms completely blocked. take them out and clean. pour water into centre hole and make sure it comess out of all the jets. turn on with spray arms removed and open door to check water is being supplied from the pump. if no water coming out, you may have a faulty pump or pump capacitor.access the pump and see if it is warm. if so fault may be the capacitor - a cheap part
May 09, 2007 | Candy CD623X Free-standing Dishwasher
Dishwashers Logo
281 people viewed this question
Top Danby Dishwashers Experts
Oloyede Monsuru
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
