HI you can purchase network unlock code for your samsung SGH-E390 mobile from sites like TheUnlockSpot.com they are providing unlock code for all mobile models at reliable cost.You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone .
HI if you want to unlock your samsung A997 mobile from network lock .Then visit sites like TheUnlockArena.com they are providing unlock code for all mobile models at reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone .
hi to get codes visit prounlocking.com here they ask you the network name to which your mobile is locked .finally they send you codes to unlock your mobile.
it is impossible for you to bypass password, either you use the formal password you used before or you need to unlock the phone for you to get access to the phone again.
First you will need to obtain the IMEI (serial number) for your handset. Type *#06# from your handset. The number that appears is the IMEI. Once you have this number you need to contact the Mobile Operator Customer Service department or use an online Subsidy Unlock service.
The phone must be in portrait mode. Once in portrait mode hit the Dial button on the touchscreen.
Type #7465625*638*Unlock Code #. (Unlock Code is a unique 8 digit number). Device will reply: Network Lock Deactivated.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
To unlock your samsung mobile,follows these steps
Do a custom reset:
*2767*2878# once this has finished rebooting turn the phone off.
Next
a SIM card from a different service provider needs to be pushed half in
- (Push it fully in then slide it back out by about 1/2 a centimeter),
Turn on the phone - you will now see an "Insert SIM" message,
Now perform a full reset:
*2767*3855#
When the phone powers off, quickly push the SIM card fully in, and let
the phone power back up.
After you do the reset, check and make sure that your Network lock is active by pressing *#7465625#
If it isn't active you must use this code to reactivate it:
*7465625*638*00000000*00000000#
Then you have to deactivate the SP lock first. To do that you need to input:
*7465625*77*00000000*00000000# (this will reset the lock)
Then you enter: #7465625*77*00000000# (to disable the SP lock).
Then you disable the Network lock: #7465625*638*00000000#
