Question about Mitsubishi WL-82913 82" Rear Projection HDTV
Is there a replacement ballast for WL-82913? I'm changing out the CAP on the SUB-POWER board, and hope that solves the firing problem, but if not, is there anywhere to buy the ballast?
SOURCE:
  • 87 Answers
SOURCE: DIGITAL MODULATOR FIND PART NUMBER
Mitshubishi part #934C066001.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Jul 13, 2007
yankeegurl
  • 121 Answers
SOURCE: Mitsubishe WL 82913
does the lamp indicator light as red? let me know what the status light does...is it blinking or solid give me some info and I should be able to help you also mitsubshi had some problems with jamicon capacitors with a thousand uf and above ratings that are no good 95 percent of all dlp problems can be traced to those bad capacitors
Posted on Apr 12, 2008
  • 18 Answers
SOURCE: timer light is flashing tv want come on
REPLACED 4 CAPACITORS ON DM BOARD. 1000uf/16volt.
Posted on Jun 29, 2009
Mr_Wizardtex
  • 205 Answers
SOURCE: no picture !
Suggest ebay
SOURCE: Mitsubishi WL-82913 will not turn on, green power
It is a capacitor on a circuit board. You access it from the back of the tv, however I do not remember much more about the repair except that there were two identical capacitors, and the repairman changed them both out in about 10 minutes. Still charged $200.00 plus dollars for the repair, but apparently he knew extractly what the problem was with doing any other testing so it must be a common problem with the set.
Posted on Dec 27, 2009
Mitsubishi WL-82913 will not turn on, green power on light blinks continuaously but unit does not turn on. Any suggestions or ideas as to what the cause may be and is there a known fix? Thanks for your...
Dec 01, 2009 | Mitsubishi WL-82913 82" Rear Projection...
It keeps shutting off. Anywhere from 2 or 3 times
Could be several things. First replace lamp.Remove lamp door and put it back on making sure tab on door presses door switch downward when closed. Can you heard spinning noise from front. Bad color wheel will cause shutdown. Look at big cap on ballast . iff swollen replace lamp, ballast and power board. Is voltage to ballast from power board below 350 volts if so replace power board. hope this helps. Most common are lamp and door switch in up position rather than downward .
Nov 24, 2009 | Samsung HL-S5087W DLP TV
No picture !
Suggest ebay
Jun 29, 2009 | Televison & Video
Timer light is flashing tv want come on
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Jan 22, 2009 | Mitsubishi WL-82913 82" Rear Projection...
Mitsubishe WL 82913
Apr 10, 2008 | Mitsubishi WL-82913 82" Rear Projection...
WL-82913 Lamp fails and TV turns off every hour or so
We have the same problem. A 14,000 dollar TV that you cant even get a lamp for. I 'm thinking of a class action lawsuit. This is ********!!!!!!!!!!!!!!!!!!!! Please respond if your interested
Jan 12, 2008 | Mitsubishi WL-82913 82" Rear Projection...
Mitsubishi WL-82913 82" Rear Projection HDTV Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
