Cannon i 860 can't get the cyan to print - have run cleaning operation several times deep cleaning @ least twive & checked ink tank visually put new ink tank in put a Q tip to the head there is ink - I'm stuck
  • 49 Answers
Then try this, it works for me!!!
Canon will hate me for this.
1. Remove ink cartridges.
2. Remove print head.
3. Go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head being careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air-dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Posted on Jul 06, 2008
My canon c3480 not printing cyan, how can i fix it this problem
First confirm that the cyan ink cart actually has ink in it.
If you do have ink, run a "head cleaning" In the printer driver, there should be a "Maintenance" tab, and in that should be a "Cleaning" button. You may also have a "Deep Cleaning" capability. Try regular cleaning first, and see if that clears the probem.
Aug 17, 2016 | Canon ImageRunner C3480 Color Copier
My cyan ink won't print. i have tried EVERYTHING.
The printer cannot use photo inks like Photo Cyan or Photo Magenta. Be sure to use "BCI-6 Cyan" in position 5 - farthest to the right.
Nov 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cyan missing on parts of a print out - Canon MP500
Common problem with this (and other) canon printers. I usually just lift the cover and lift the highlighted tank out and put it back in, sometimes I have to do that 2 or 3 times before it will let me print. If lifting that tank doesn't do it, try lifting all the tanks and putting them back. Eventually you will get a message that the tank you are refilling is empty (even if it's full). When that happens, press and hold the "stop/reset" button for 5 seconds (this is from Canon) then you will get a message that Canon will not be responsible for damage to the printer because you are using different ink than theirs (just ignore it). You can also try cleaning the contact points on both ink cartridge and on printer w/ cotton swab lightly dipped in alcohol.
Jul 31, 2009 | Canon Pixma MP500 All-In-One InkJet...
Pixma ip4200 willl not print Cyan
I think the problm lies between the ink tank and the printhead. When this passage runs dry, sometimes it takes time for the ink to fill this passage again. Try printing again after a day or two.
Jul 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
The ink cartons are full. Printing is not taking place
Hi I think I had a similar problem, I let the black and cyan run down really low. then it took a week to replace the cartridges. The result was no black and cyan. I put in new cartridges and of course no colour.
Solution: Take out the cartridge holder and take a cotton bud and soak all the ink pads in alcohol (no not beer)
I used clear alcolhol from the chemist, the reason for this is it dries out very well after the clean process with no contamination. Give the ink pads a good soak and rinse out in very hot but not boiling water and allow to dry. Then go through the deep clean process in 'printer maintenance'
You may have to do that several time but be patient and it should clear out and start to print again.
Mar 30, 2009 | Canon PIXMA MP780 All-In-One InkJet...
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
I960 canon printer
Lift lid ,let carriage stop in middle, un-plug the printer > Remove all ink tanks > Remove print head > Soak print head in > 3 parts very warm water an 1 part ammonia over night. Rinse under faucet with water directly over ink ports, shake out excess water,(if when you shake it out and if color still comes out repeat soaking for another hour or two and rinsing again ,HAD TO DO MINE TWICE) let air dry. (hair drier helps) Cured my problem for a while ,but if not used almost every day, this will happen again, I also use compatible ink tanks. Don'T believe the inks are as good as Canon Ink. But who the hell can afford them. So fill your owe with Canon ink from Canon. Still seems that the cyan always dries up first. Good luck Lestero1
Oct 18, 2007 | Cannon Canon i960 Photo Printer
