S11-0a remote neither of those remotes seems to be mine. the buttons described are not on my remote
  • underbe Jul 06, 2008
    no problem. i have not been able to find anything either. i used to have the pdf but formated my hd. at the time i did not think it would be hard to find again...
    Master:
  • 382 Answers
yeah im sorry to say i was not able to find out the manual for your specific model,thats why i put up another model because i thought you will have the same buttons..but anyway i will be really glad if you want me to put up the codes i will surely help you with the link..always at your service!..thank you!!..
Posted on Jul 06, 2008
Blue Star 1.5 ton 5 star inverter split AC remote "TEMP" button seems not functioning. does any one help me? how to check this function as always remote is showing set temperature.
does that on mine as well
the temp is what is on the inside wall unit when turned on the remote reads 25 and the inside unit reads 30 but eventually comes down to 25
Apr 14, 2017 | Star Heating & Cooling
Mustang alarm
Ford sold a Ford branded alarm through the parts department. These sometimes were a dealer installed option on new cars. Mine would randomly stop responding to the remote and I would have the same symptoms as you describe. I had it removed and the original equipment factory system still worked. Be warned, if you have the Ford "accessory" alarm, your key fobs (remotes) are different and the method to program them is different from what you will read online. You can tell if you have the system by looking at your key fob. The standard Mustang key fob is a 4 button (lock, unlock, panic, and trunk). The accessory alarm uses a 3 button remote and clicking unlock twice would pop the trunk. I really wish I had a picture of the remote because there are 3 button Ford key fobs for cars without a trunk release although I don't think you should have one on a Mustang. Long story short, if you have the accessory alarm, you can solve your problem by having it removed but you will need new 4 button key fobs to remotely lock/unlock your doors
Apr 04, 2014 | 2003 Ford Mustang
The source menu on my tv keeps flashing and volumn goes up and down by itself
Pull the batteries out of your remote. Does it still flash and yell at you? If no, replace your remote. If yes, call the manufacturer, they should be able to point you in the right direction regarding your Envision. I'm not very familiar with your model, but it's not a problem I've encountered before. Since your remote doesn't work perfectly anyway, it could be causing exactly what it is that your describing. Your OK button could be stuck in the depressed position, like it's being held down, and since it's usually near the volume buttons, it seems to be the most likely cause.
Jan 31, 2013 | AOC Envision L32W461 32 in. LCD HDTV
Manual for URC-6962B00 oneforall remote
I have the 6962B000 Kameleon remote and the manual. Could make a photocopy but but shoud I do that?
Apr 19, 2010 | One For All URC-8011 Remote Control
My remote is about 4 yrs old and some of the
There seems to be an issue with the Harmony 880/890 where, after a time, certain buttons that are used more often become unresponsive (though 4 years is not a bad run!) They either need to be pressed very firmly (and sometimes held down for a few seconds), or they stop working entirely. This is probably due to the wearing out of the metallic bubble button that is beneath the film adhesive of the circuit board. If this has happened, the repair can be tricky. In most cases if only one or two buttons are the problem, you may want to try the 're-mapping' strategy as described below. Remember, the beauty of this remote is that you can create 'soft' keys using the LCD screen and re-map almost any key you like. Here is a link to a good post on the Logitech forum which describes how to test the buttons and re-map them. Good Luck!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9796&p_created=1232640364&p_sid=1E1TzrCj&p_accessibility=0&p_redirect=&p_lva=3219&p_sp
Dec 17, 2009 | Logitech Harmony 890 LCD Remote Control
Remote control buttons not working
One...what kind of remote. Two...what buttons. Three...CLARIFY WHAT YOUR PROBLEM IS AND DESCRIBE YOUR DEVICE. Were here to help not play 21 questions.
Sep 12, 2009 | RCA Universal Remote Control
Sony Remote Control RMTD152A All of a suddend the buttons on the remote seem to be scrambled. When I push pause the video goes to menu. When I push enter to select play, the dvd player shuts down. When I...
If there is a stuck button (or buttons) on the remote it may behave weirdly, also in such a way that you described.
If this is the case, you just need to disassemble the remote and clean all the parts well with some ethyl alcohol.
All the parts means the rubber pad with buttons, circuit board with contact tabs and the housing.
When you clean the housing, be sure to clean all of the holes for the buttons, this is where the dirt accumulates and makes buttons stick - it keeps them pressed so the remote gets weird as you press other buttons.
If it's not that, then it may be damaged contacts, faulty solder points (battery tabs, capacitors, quartz, LED) or something else.
regards
3rq8 (Triarcuate)
Jul 24, 2009 | Sony RMT-D152A Remote Control
Flashing green light on Sears garage door wall opener HBW0777 1/2
Same problem - The flashing wall button indicates the remotes are locked out. I fixed mine by pushing the green button on the back of the opener. I did nothing else , just left the LED time out.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Programming rca universal remote for my toshiba tv
I can't exactly help you, but can you tell me how you programmed the remote to your TV, because I cannot get mine to work...
Apr 03, 2008 | Toshiba 42H81 42" Rear Projection...
Remote appears frozen
I got the same issue with mine, and hooking to the computer and upgrading the firmware worked for me. I first had to take the bateries out and let it sit for 24 hours so it would loose the codes inside. No problems after that.
Jan 30, 2008 | Logitech Harmony 550 Remote Control
Televison & Video Logo
Top Televison & Video Experts
