Is this a sealed bearing?
Thaks, reg501, that was very helpful.
I pulled the back off and looked inside. Although I'm sure it is the tub bearing that is making the noise, it does not seem excessively worn per the test you suggested. Seems pretty tight, actually. Is there a way to lubricate this bearing or is it sealed? If it is a sealed bearing this failure is way premature and should be taken care of by Whirlpool, in my opinion.
Thanks, again,
Owen
  • 413 Answers
There is no way to lubricate the bearing. However.....I do know...that there were some models that were manufactured with inferior tub bearings. You should consider contacting Whirlpool for possible warranty concessions related to your particular issue.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 06, 2008
Fridge washer GLWS1349AS0, have inner tub out, trunion lifted, not off yet due to slight rust. How do I change spin bearing and tub seal? thanks.
To remove the trunion totally reattach the inner tub to it and twist the inner tub,with the tub attached it gives you much more leverage to twist and pull the trunion off. After its off pull the small brass ring with the O seal in it up the transmission shaft and pop the tub seal off. To replace tub bearing remove the bolts on the side of the side of the outer tub off from the tub support and pull tub off of trans. shaft. to remove bearing flip tub upside down and remove the 2 screws from the tabs on bearing and turn tub back right side up and use a screwdriver on the top of bearing and knock it out of outer tub,push new bearing in by hand most of the way,being sure the tabs on bearing is lined up w/notches on tub and use old bearing placed on top of new one and drive it down all the way,reinstall screws into tabs. All the surface rust should be sanded off of trans shaft. Re install outer tub and secure with the bolts into tub support. push main tub seal into flange with normal palm pressure,install new brass ring and MAKE SURE O RING DOESNT POP OUT OF IT ( a little dawn,palmolive joy liquid dishwashing soap around inner part of o ring inside of brass ring will help it slip on easily) I use the old brass ring and press it over new brass ring to assist in o ring not popping out,once new brass ring is inserted ok and oring in place remove and discard old brass ring. Reistall trunion and inner tub ECT ECT ECT
Gene
Aug 12, 2011 | Frigidaire GLWS1349A Top Load Washer
I've recently done the roller bearing fix on my FAV6800AWW, now..
cysloane
You have a Tub Seal leak for sure. Did your Clutch Pulley use the upper bearing ring? If you don’t have any Outer Tub bearing noise you may get around replacing the Outer Tub Bearings.
Take a look at these links and see if they will help. Getting the Spinner Assembly removed without breaking one off requires care. Soak in Liquid Wrench or PB Blaster. Even after doing that I broke one off. I had the bolt hole drilled out and Stainless Steel Helicoil inserted in.
Here is the process for a Series 10 machine I did a tub seal replacement on. If you follow my post I’m a DIY’er with basic mech. skill sets. I’m a Electronic Technician by training and and learned craft skills. I feel you can do this if you felt OK with my Clutch Maintenance/Replacement post.
I would replace both the Tub seal and the Tranny O ring seal.
I used an air impact tool to remove the Spinner Bolts and the 1.75” Spinner Nut. You might be able to get away from using the Spinner Nut removal tool if you lock the Spinner Assembly as shown on page 47 in the SM.
See this post for links on Tub Seal and Outer Tub bearing replacement.
Good luck and I feel you can do this. I’m no expert but will try to help you……..Rich
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Has a squeek when it is in the spin cycle
mostly the motor problem  and other possible problem can be  that a bearing is bad.If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
May 08, 2009 | Washing Machines
Noisy when spinning
The noise coming from this machine as it spins is due to -- If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Picture1 - Picture2
May 07, 2009 | GE WJSR2070B Top Load Washer
Maytag washer MAV551EEWW top load with loose tub
Picture1 - Picture2
May 07, 2009 | Washing Machines
I moved my washer cause of relocating and now when on spin cycle it makes a howling noise, what can i do to fix the problem, its a front loader gallery series??
Picture1 - Picture2
May 05, 2009 | Frigidaire Washing Machines
Made a loud noise and drum stopped moving
Picture1 - Picture2
May 03, 2009 | Hotpoint WMA40 Front Load Washer
Grime on clothes from washer
Picture1 - Picture2
Mar 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Sport Duet: Purchased back in August 2006 the Spin Dry Cycle used to be very quiet - In the last month the cycle "sound effects" resemble the warm up of a commercial jet...
To test for bearing failure, open the door, pull back the door seal then grab the plastic outer tub with one hand and the inner basket with the other hand. If you can lift on the basket and wiggle up and down, the tub bearing is bad.
The tub bearing is contained in the rear half of the outer tub. To replace the rear half of the outer tub requires total disassembly of the machine. The top, console, door seal, front panel, rear panel drain hose, pressure hose etc. all have to be removed. Then..the entire outer tub has to be removed and split apart. The basket will need to be removed and the rear half of the tub replaced,,,It is a very time consuming job, if you are mechanically inclined, you can do it, if not, consider a professional. Cost to repair by a professional will run around $450.00. Outer tub cost is around $300.00.
Regards,
reg501
Jul 05, 2008 | Whirlpool Washing Machines
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
