Re: I installed a geforce 6600 gt oc video board and all...
After you've installed the video card, you need to install the drivers for it with the cd that came with it. If you did not receive a cd with it, then you can download the software package here.
Hello dimash, you must remove nvidia old drivers before installing latest driver, go to Start> Control Panel > Uninstall a program > Nvidia Drivers Remove, Restart Computer, i found newest drivers for you video card, which operating system did you install on? To Change Resolution Go to Nvidia Control Panel > Display > Change Resolution > Color depth : Highest (32-bit)
Click save driver to your computer, install the driver, don't forget to restart the computer. Here is the links.
Copy and paste link into your browser and press enter.
I feel you got a failing video card my friend as if the slot failed you would not have got that far!.
Try another video card, you can get them cheap from Fry's.com hold on to your receipt just in case you have a failed motherboard (witch i can doubt that)
Support for Microsoft DirectX 9.0 Vertex Shader 3.0
Displacement mapping
Geometry instancing
Infinite length vertex programs
Pixel Shaders
Support for DirectX 9.0 Pixel Shader 3.0
Full pixel branching support
Support for Multiple Render Targets (MRTs)
Infinite length pixel programs
Next-Generation Texture Engine
Up to 16 textures per rendering pass
Support for 16-bit floating point format and 32-bit floating point format
Support for non-power of two textures
Support for sRGB texture format for gamma textures
DirectX and S3TC texture compression
Full 128-bit studio-quality floating point precision through the entire rendering pipeline with native hardware support for 32bpp, 64bpp, and 128bpp rendering modes
64-Bit Texture Filtering and Blending
Full floating point support throughout entire pipeline
Floating point filtering improves the quality of images in motion
Floating point texturing drives new levels of clarity and image detail
Floating point frame buffer blending gives detail to special effects like motion blur and explosions
Intellisample 3.0 Technology
Advanced 16x anisotropic filtering
Blistering-fast antialiasing and compression performance
New rotated-grid antialiasing removes jagged edges for incredible edge quality
Support for advanced lossless compression algorithms for color, texture, and z-data at even higher resolutions and frame rates
Fast z-clear
High-resolution compression technology (HCT) increases performance at higher resolutions through advances in compression technology
UltraShadow II Technology
Designed to enhance the performance of shadow-intensive games, like id Software's Doom 3
TurboCache Technology
Shares the capacity and bandwidth of dedicated video memory and dynamically available system memory for optimal system performance.
PureVideo Technology
Adaptable programmable video processor
MPEG video encode and decode
High-definition MPEG-2 hardware acceleration
High-quality video scaling and filtering
DVD and HDTV-ready MPEG-2 decoding up to 1920x1080i resolutions
Dual integrated 400 MHz RAMDACs for display resolutions up to and including 2048 × 1536 at 85Hz
Display gamma correction
Microsoft® Video Mixing Renderer (VMR) supports multiple video windows with full video quality and features in each window
Advanced Display Functionality
Dual integrated 400MHz RAMDACs for display resolutions up to and including 2048x1536 at 85hz
Dual DVO ports for interfacing to external TMDS transmitters and external TV encoders
Full NVIDIA® nView™ multi-display technology capability
Advanced Engineering
Designed for PCI Express x16
Support for AGP 8X including Fast Writes and sideband addressing
Designed for high-speed GDDR3 memory
Advanced thermal management and thermal monitoring
NVIDIA® Digital Vibrance Control™ (DVC) 3.0
DVC color controls
DVC image sharpening controls
Operating Systems
Windows XP
Windows ME
Windows 2000
Windows 9X
Macintosh OS, including OS X
Linux
API Support
Complete DirectX support, including the latest version of Microsoft DirectX 9.0 Shader Model 3.0
Full OpenGL support, including OpenGL 2.0
GeForce 6 Series GPUs Features Comparison:
Feature
GeForce 6800 Models
GeForce 6600 Models
GeForce 6200 Models
GeForce 6200 w/Turbocache
Microsoft® DirectX® 9.0
SM 3.0
SM 3.0
SM 3.0
SM 3.0
Graphics Bus Technology
AGP 8X/PCI Express
AGP 8X/PCI Express
AGP 8X/PCI Express
PCI Express
NVIDIA® Intellisample™ Technology
3.0
3.0
3.01
3.01
NVIDIA® SLI™ Technology
X2
X2
n/a
n/a
NVIDIA® PureVideo™ Technology
X3
X3
X3
X3
NVIDIA® TurboCache™ Technology
n/a
n/a
n/a
X4
64-bit Texture Filtering and Bending
X
X
n/a
n/a
Effective Memory Interface
256-bit
128-bit
128-bit
128/64-bit
Memory
GDDR35 and DDR
GDDR35 and DDR
DDR
DDR
Process
0.13 micron
0.11 micron
0.11 micron
0.11 micron
RAMDACs
400 MHz
400 MHz
400 MHz
400 MHz 1. GeForce 6200 models do not include compression technology. 2. NVIDIA SLI: Available on SLI-certified versions of GeForce 6800 Ultra, 6800 GT, 6800 GS, 6800, 6800 XT, 6800 LE, 6600 GT, 6600, and 6600 LE PCI Express GPUs only. 3. Features may vary by product. Some features may require additional software. 4. Available on select GeForce 6200 models only. 5. GDDR3 - GeForce 6800 Ultra, 6800 GT, 6800 GS, and 6600 GT only.
HELLO THERE You may want to boot into bios and see if the video display is set to agp or pci and change it from their than save and reboot and if that does not help boot into the safe mode and uninstall the update and if needed reinstall the card,,, geforce has been having a problem with these updates and depending on your operating system it can be non compatable so, please try these solutions ok best regards michael
run the onboard if you have one and go into the bios there's normally an option to choose what order to boot graphics devices eg. PCIE>IGP etc hope this helps.
Its most likely drivers. Completely uninstall all Geforce drivers and and software. Some video uninstall programs only remove the software and not the drivers. You'll need to go into device manager and uninstall the video drivers from there. Double check to make sure MX440 drivers are gone as well. When you restart and windows wants to install your new card, cancel it, then run the Geforce setup program. That way you won't get conflicts with a windows basic driver. Then make sure you have Directx 9c installed. Directx 10 isn't necessary because I don't believe the 6600 supports it anyway. Good luck
