Question about Gateway GT5228 PC Desktop
Monitor flashing from normal to black
Ok. ive had this problem for awhile now and not sure what to do about it. no matter what application i use on my pc after its on for like 10 minutes the screen keeps flashing from normal to black to the no signal screen to back to normal , its happening quite frequently. ive tried replacing my dvi cable, cleaning it, making sure everything is in tight. i've already brought it in to the shop twice. first time they said they could'nt find the problem. second time they said it's a virus. i've scanned it with multiple anti virus programs and its still happening. any help would be much appreciated.
This is incorrect. I have the same problem. I purchased a new monitor. a different brand and all was fine for about a month...now it has returned. I think it may be related to my graphics card...that is my next step to fixing this problem. Let me know if you had any luck Cheers
Ben
Posted on Jul 06, 2008
    President:
  • 173 Answers
If this is a lcd monitor, sounds like your back lamp is going out. check to see if you can see your desktop by looking at different sharp angles from above the monitor and if you can barely make out your desktop icons. If it is the back lamp, I am sorry to say it will be expensive to replace (I had the same problem myself and it was just cheaper to replace the monitor).
How do I repair my 19in LCD monitor, it receives video signal, but goes black screen?
Connect the "bad" monitor to the VGA-out port on a notebook/laptop computer, to see if it works normally when connected. If not, then the monitor is "dead".
If it works fine, check the "screen-resolution" of the computer's video-card, to see if the values exceed the capability of the monitor.
May 05, 2015 | Computers & Internet
My computer when i start it up it goes to the normal and when i get to my desktop the screen goes all black but i can use task manager to do things but i want to have my pc back. ive tried to restore but...
when task manager appears on the black screen, click on applications tab and then click new task and type explorer.exe and then press ok. your normal desktop should appear
Mar 28, 2011 | Acer Aspire 1410-8414 Netbook
Monitor flickers or 1/3 turns black, have tried wiggling cable, and moving/tapping monitor, sometime it works great, other times i fight this every few min. Doesn't matter if i turn computer all the way...
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
HP W1907 Monitor goes black after resolution change
This is normal, but it should only take less than a minute for your computer to readjust, make sure all your graphic card drivers are updated, for that may be a factor.
Contact me if you need more detailed explaining.
Regards,
Asitomani
Jan 30, 2009 | HP w1907 LCD Monitor
Tv gone black and white
try letting it run for a little while sometimes it just needs time to warm up after not being used for awhile. unfortuntly i am not completly sure but i will look up more information on this.
Jan 03, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Downloading games
the application says thta not a signed application. whwt should i do
Nov 09, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Computer Does not Boot correctly, Monitor is Black.
try to reinstall the OS..if it doesn't work then there would be a problem with ur motherboard becaouseof failure of IC's. So contact the service men.
Sep 27, 2008 | IBM Aptiva E 240 (2158240) PC Desktop
Flashing on and off
your TFT monitor haveing Power supply Problum please contact if you are in mumbai india on 9820068101 he will come and change your supply
Aug 15, 2008 | ViewSonic VA702b 17" LCD Monitor
My monitor will only blink a black or white screen.
check the warranty online for your screen.. go the the acer support website and look up warranties, and it will ask for a really long number on the back of your screen, and it will tell how long the warranty is good for and what to do with it.
Mine is doing the same thing. flashes white then black and that is all
Dec 31, 2007 | Acer AL2016WBbd Monitor
Monitor flashing
I have a similar problem with my screen, same one, 15". For a period of two years it would turn black for an instant and resume functioning. Since two weeks it only flashes the picture for an instant and then turns black again. We opened it up to check the wiring but nothing wrong there. We are 99.99% sure that the problem is in the screen itself and has nothing to do with drivers or anything else in the computer.
If you bought it less than 3 years ago and since it is probably a result of faulty construction, it should fall under warranty (by european law).
I am going to take mine to a repairman tomorrow, i will inform you wether the screen can be repaired or not.
Greetings,
Rengenier.
Oct 10, 2007 | LG Flatron L1715S 17" LCD Monitor
Gateway GT5228 PC Desktop Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
