Question about Refrigerators
Our icemaker stopped functioning. It is a Whirlpool Conquest Gold refrigerator. Are there some simple things we can try?
  • 481 Answers
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad,
  •  or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  •  In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • Note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 06, 2008
Whirlpool gold refrigerator electronics for icemaker and water are dead
Moisture damage or bad connection. Take apart and check wires and circuit board.
Jul 24, 2014 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker will not refill
if the water is on its probably time to change the water valve on the unit. They go bad quite often. Hope this helps.
Jan 23, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker on side by side not working
Change out your ice maker. If your icemaker has worked for 6 years, you got lucky! They normally have to be changed out every couple of years. We have an unlimited inventory of appliance parts for Whirlpool, so please call us to send your parts out and we'll get them out right away!
Sep 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
In the door ice maker has stopped working. the light controller s
when you look at this icemaker there are 2 sets of strippers 1 stationary the other moves. teh one that moves is normally at 2 o'clock position facing the front cover of icemaker. if these teeth are in anyother position for longer than 10-20 minutes then you most likely have a bad motor module on the icemaker, this is a very easy repair you will need partnumber 8201515 from whirlpool or local appliance supply house. thx peyton
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Conquest IceMaker
HAVE YOU CHECKED YOUR WATER VALVE LOCATED AT THE BACK BOTTOM RIGHT OF THE APPLIANCE THAT MIGHT BE THE CAUSE OF THE ICE MAKER NOT WORKING.LET ME KNOW IF YOU REQUIR FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Sep 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refrigerator icemaker leaking water
hi there,
sounds like the ice or water actuator or paddle is broken. purchase a new paddle and replace it.
the reason you have leak is because you have warm air entering through the broken part into the freezer.
can you provide me with the model # and i will send you a part breakdown.
Sep 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator Whirlpool Gold Conquest (Side by side)
the ice maker is of a poor design. There is a wheel that essentially is the mechanical timing device of the icemaker. The shaft in the wheel is of poor design and it breaks leaving a non-functioning useless ice maker. Whirlpool does not sell the wheel & shaft assembly - you have to virtually buy a new icemaker. Takes about 10 minutes to replace. Charge for the part = $107; charge for the labor = $175
Aug 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold icemaker not working Model GD5SHAXLB02
problem with the heater or the thermastat of the ice maker
May 11, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not making ice
The same thing happened to my Whirlpool gold. Defrost it for 24 hours and the ice maker now works.
Apr 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
