Leaking AC condensate drain pan - Heating & Cooling
  • Anonymous Nov 22, 2008
    I have a property service business and we're seeing a lot of cracked pans on the FV4BNF006000AAAA, FV4BNB006000AAAA, and FV4BNF005000AAA models. These have been installed by several different qualified contractors in multi-million dollar home.
    Is this a larger scale problem?
Ok need a pan tool were can i find one
Posted on Aug 24, 2008
That's not the problem. It has a 1" crack in bottom of the thin plastic drain pan. I need to figure out how to seal that crack. Replacing the drain pan would be a major project, due to it's attic location and it sits in the drain pan.
Posted on Jul 06, 2008
  • 828 Answers
Check the drain line for possible plugged trap. Blow back through it in some way to try to clear it.
4 Suggested Answers
SOURCE: Condensation leaks out front of unit into the house.
Hi, no don't drill holes in bottom tray, to make drain, that's design, you need to keep water there, the fan usually pick up water(moisture) and add to your air inside your home, otherwise the air in your home will become to dry, dry air will create static electricity all over your home, from your carpet to your clothes, you need to level your unit horizontally, put a spirit level, and you should have a slight pitch, from front to back, good luck.
Posted on Aug 04, 2009
motor1258
  • 6674 Answers
SOURCE: Duo Therm 1500 AC leaking water inside RV after
On your cold side air coming in, does the ductwork have any insulation on it? Also The evaporator (front part, up where your filter is ) may have a plugged drain tube, depending on year make & model. Not uncommon for some to have a cracked drain pan as well. Your best bet may be to pull plastic cover off unit, then look on side of evaporator housing & see if you notice a tube sticking out side for drainage. It may be plugged if there is one there, use a piece of coated wire or similar and try cleaning it ou, carefully, don't ram it in there and hit coils too hard.. You can remove the 5/16" head screws that hold cover over evaporator, and pull that cover forward & have a look as well.
Posted on Aug 13, 2009
mrjfisher
  • 141 Answers
SOURCE: my condensate drain pan is cracked inside the air ...
If water was in it in the winter it could have froze.
If your pan has a heating element in it, and it didn't turn off. It could have the same effect as being in the Arizona sun. Or just old age.
Posted on May 19, 2010
Why is there water on my furnace when the a/c is running?
Condensate normally drains into a pan that either empties into a floor drain by gravity or empties into a pump inlet for discharge outside. The drain pan may be clogged, preventing it from emptying or, more likely, the drain pan is leaking condensate.
Jun 28, 2014 | Heating & Cooling
My ac unit is leaking through the coil box, I cleaned the drain, but it still leaks from the side of the box. Could it be cracked? the unit is 9 yrs old
Could be a cracked condensate pan. this may require replacing the pan or there are sealing sprays on the market which you can buy at HVAC stores.
Dec 11, 2012 | Weather King Heating & Cooling
Where is the drain pan on a carrier weathermaker 8000?
Hello, the drain line will be located under the unit near the condenser coil. Sometimes it can get blocked and the condensate will settle toward the front of the unit and leak from the unit. Also, make sure the unit is tilted back in the window about a 1/4 inch aswell.
Jul 11, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
Water leaking around screw of ac vent in bedroom. it is a slow drip that is constant even when the ac shuts off
From what you described, it sounds like the drain hole in the condensation pan under the unit is clogged. Also, the unit may not be titled down enough at the rear of the unit. Generally, 1/4" to 1/2" is required, so that the water in the condensation pan will flow to the rear of the unit, where the drain hole is. These 2 things are where you need to start troubleshooting.
I hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | Heating & Cooling
There is water leaking out from the bottom of my furnace. It leaks whenever the ac is running.
Hello, sounds like a clogged condensate line or a faulty condensate pump if the unit has one. Cleaning the drain line should fix the problem.
Jul 12, 2011 | Heating & Cooling
My coleman rv ac unit is dripping condensation inside the camper, what is causing that?
It is possible that the drain hole on condensate pan is plugged and causing water to over flow pan. Remove cover from unit and check drain line.Clean coils andpan as best you can and clear drain hole. Add a small amount of bleach to water in drain pan.This will kill any algea or bacteria that may be growing in condensate water and plugging the drain. Thank you
Jun 20, 2011 | Coleman Mach III Air Conditioner
Leaks inside when running
you might have a drain line plugged up...or a dirty evap coil...call if you need direction an what to look for...
May 12, 2010 | Dometic Rooftop RV Air Conditioner
Water leaking inside camper from roof mount ac
CHECK THE CONDENSATE PAN FOR CLEANLINESS, CLEAR THE CONDENSATE DRAIN LINE, INSURE THERE ARE NO CRACKS IN THE DRAIN LINE
Sep 18, 2009 | Carrier Heating & Cooling
Should there be a condensation hose of some sort. I have a leak and can't find where water is coming from
These units do not have condensation "hoses", they have an evaporator pan than is located under the evaporator coil and catches the condensation and then lets it drip down onto the roof and then off the RV. If your AC is leaking into the inside, remove the inner shroud and feel up into the evaporator area for the pan. If it is full, then the drain holes are plugged. They are not easy to get to. Remove the upper shroud and then remove the front cover over the evaporator. At the base of this area is the pan, on each end is the drain hole. Clean them out and all should be fine.
Hope this helps,
Jeff
Rate me please!!
Jul 07, 2009 | Coleman Mach III Air Conditioner
Furnace is leaking water
This is not a lot to go on.
I assume since you called it a furnace, you have hot air heat and central air conditioning. If so, the only way a furnace/AC unit can generate water is by condensing moisture from the air. This is common to all air conditioning and removes humidity from your home. If so, this water, called condensate, must drain. The condensate is collected at the AC cooling coil that is typically located on top of a vertical upflow furnace or downstream of a horizontal furnace. If the drain is clogged, it will overflow and create a mess in and around the furnace. If this is your problem, cleaning and clearing debris may solve the issue. I suggest starting with the easiest accessable part of the drain path. You may need to open the panels enclosing the AC coil and clean the small pans at the bottom of the coil and clear openings from above that look similar to a laundry tub drain. If you get that far and find rust holes in the pan, repairs are needed. If you have an electric condensate pump that may also be the cuprit and require cleaning. Check and clear all drain lines from the coil connection to the final dicharge - sump pit or outside.
Oct 05, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
3,177 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
