Vulcan 901 ducted heater not igniting but have pilot light. have tried changing batteries in remote without any success
3 Suggested Answers
  • 86 Answers
SOURCE: vulcan cx90 ducted heater
240 volt wiring required.
Posted on Mar 17, 2008
  • 86 Answers
SOURCE: Vulcan ducted heating
not possible
Posted on Mar 28, 2008
SOURCE: Stadt Ducted Heater ignition problems
Could be a number of things
Sounds like it the gas valve. If the gas Valve isn't opening or is burnt out then no gas will flow through it.
Also it the pilot is blocked then you wont get and gas coming through to light it up.
I am forever replacing gas valves on the buffalo series units and have found this to be quite a common problem on older units.
Posted on Aug 21, 2008
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
Vulcan express gas continuous flow/model # 230010N0/serial # 66669/ Date 19-08-98. I can hear and smell gas when trying to ignite the pilot light and the igniter spark, "sparks", but pilot light...
VULCAN water heater continnous model number 23001ono. im looking for a brass nut that sits on with a very small hole, with a number on it (25)
Mar 10, 2011 | Heating & Cooling
Describe your Problem i have a quasar vulcan gas heater pilot light is on but wont ignite. can hear it clicking trying to ignite what is the o=problem . this heater maybe about 20 years old
What do you mean by the pilot light is on but won't light. Do you mean that there is gasbut won't light. If so the spark may not be hitting the pilot properly or it may not be getting enough gas. If lighting but continuing to spark the sensor may need cleaning. This can be cleaned with steel wool (not sand paper), probably will need to disassemble the pilot asembly The pilot may also be dirty reducing gas flow. If this is the case dis-assembly will be needed and the pilot cleaned.
Sep 05, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Pilot lights but won't stay on in my older style vulcan space heater. thermo couple was replaced last year.any ideas that i could try thanks
Most common cause of pilot light problems is air movement. If your space heater exhausts gas through the roof, ensure the cap is on and level. If not, outside air movement will blow out the pilot. If you do not have an exhaust gas duct, check that the unit is positioned so that it does not blow air back onto itself from walls, furniture, etc, and ensure no other devices that move air are aimed towards the unit. The unit also needs to be placed away from central ducting, including return vents.
Hope this helps!
Aug 09, 2010 | Vulcan AUW230A Heater
Can't seem to ignite pilot on a 30 year old vulcan heater. Same problem every year as winter is approaching :) Usually works fine once pilot is on though.
It's probably just a dirty pilot orifice (or a spider web), if it's been off since last winter. Try using a can of compressed air with attached straw (like you use to clean computer keyboards) and blow out the dust from the pilot orifice in the pilot assembly, which is where you light it. That should do the trick. Good luck! Douglas
Jun 07, 2010 | Heating & Cooling
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Vulcan space heater lighting instructions
turn the round knob to left "the ignitation" spot, then push down the button to light the pilot.
May 07, 2008 | Ovens
Vulcan CX ducted heating
sounds like the thermocouple (that sensors the heat) may be faulty.
you will need a licensed gas fitter for repairs
Feb 19, 2008 | Heating & Cooling
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
