Question about Compaq (166361-001) Motherboard
Wrong Hard Drive capacity
I tried installing a 30 GB and then tested with a 60 GB Hard Drive and also tested with a 4 GB just to test the computer as a Master into a Compaq Desktop EP/SB Pentium 3 computer bought at an auction with no hard drive in it. These were used as colege computers and have ID numbers. None of the HD's worked properly athough the drives themselves seem to be working (at least they are powering up). I don't know which motherbaord it is. I tried to find identiifying number, but don't see any numbers except it does say Compaq and there is 575 nearby the back connectors where it mentioned the coin size battery (ths may be the battey). When the computer turns on, it says media test prob check cable. When I F10 to setup, the Primary Drive 0 and Primary Drive 2 are not there, it shows no cylinders or sectors etc. It shows Secondry Drive 2 ATAPIA, but no cylinders or sectors.
I tried settng the BIOS at default. I then restart my computer and sometimes it recognizes Drive 2 about half the capacity of the 60 GB.
I don't knowi there is any LBA jumpers or ...
I wanted to format the hard drive, but it would not let me.
I even tried booting with the XP disk, but it would not run through after I went through most of the procodure to format in NFTS after changing the partitons to unpartitioned and etc. It said there were missing files.
I have tried other cables, hard drives, tested the RAM chips (I did add one), but I am getting the same results.
I sure would appreciate some help. I have three computer and none are working properly. I seem to be the comon denominator.
Thank you
illbill
  • Bill S Jul 07, 2008
    The BIOS battery is OK.
    I am not sure how I can tell what cable should be used. Can you tell by the number of pins? The cable fit the HD socket fine, but I am not sure of the pin out etc. I tried a smaller 4 GB HD just to see if that would work and it did not.
    At one time, I booted with XP CD and the computer read the total 60 GB HD capacity. I think I tried to delete the partitioned area and then format into NFTS in the unpartioned area. I never saw the full capacity on any of the drives I tested after that.
    I tried a 4 GB, 30 GB, and 60 GB. Now the computer only sees 1/2 the HD drive capacity ex: 30 GB instead of 60 GB. I am using the hard drives one at a time.
    Thank you!
    illbill
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are the batteries that hold the BIOS settings still good?
  • 2,794 Answers
Its quite possible the BIOS isn't reading data because it doesn't recognize a 60 gig drive. Unless there is a way you can look for a BIOS update on HP.com that increases hard drive capacity. You can check on HP.com as well to see what the maximum capacity is for that computer.
Posted on Jul 07, 2008
  • 105 Answers
First you change ribbon data cable which connect hard disk
it may not be supporting more than 32 gb capacity.
first you only connect the only hard disk test for detection
Posted on Jul 06, 2008
My Dell Inspiron 6000 has Samsung Model MP0603H hard drive. The computer was working fine till this morning when it would not boot. I ran diagnostic using the Dell CD and the results stated: Error Code...
Those codes all apply to the hard drive itself..
Replacing the hard drive is all you should have to do.
Below is a link to a brand new hard drive that will work in your Inspiron 6000
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350216497944&rvr_id=119484484159&crlp=1_263602_263622&UA=%3F*F%3F&GUID=1ca6610412a0a0aad456d986fffd8c0c&itemid=350216497944&ff4=263602_263622
Aug 03, 2010 | Samsung ( MP0603H) 60 GB Hard Drive
My 7Y250MO hard drive starts clicking and after a few seconds the system locks up only fixed by powering down and restarting.
Try doing the self-test for the hard drive. It could be a sign of hard drive failure. Just boot to BIOS go under diagnostics then select Primary Hard-drive Self Test. In hp notebooks, we use f10 after turning it on to boot into bios. Ask your computer manufacturer how to boot to BIOS. If you're Hard drive passed the test you might want to try re-installing the operating system. It could be a sign of Windows crashing. If you're Hard drive failed. There you go. You have to replace the hard drive. Hope this helps.
Mar 07, 2010 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Can you let me know what is the maximum installable HDD capacity 0f Lenovo laptop 3000 C100.Can i upgrade present capcity of 40GB to 320GB ?
If you have windows xp with service pack 3, there is no limit. There is no limit if you run Vistaor Windows 7. If you don't have service pack 3, you are limited to 137 gb.
Dec 20, 2009 | Lenovo 3000 C100 Notebook
80gigs partition then reformatted and displays only 31gigs
If there are files on the drive that you need to recover, then do not format it. It sounds as though the computer that you put the drive into has an issue where the bios perhaps does recognize the drive correctly. Perhaps that can be corrected by updating the bios in the computer, and trying the drive again. Or you may want to put it back into the original computer, back up the files to other media, and then put the drive in the computer and re-partition.
What does the FDISK - "DISPLAY PARTITION INFORMATION" utility report? Do you have a copy of FDISK? If the partitoins in FDISK add up correctly, then it could just be that the data is corrupt, and windows is just unable to read. If that's the case, you should try a recovery application to restore your data..
Nov 15, 2009 | Dell Tablets & eReaders
Now used as 33 GB; want to use as 60 GB
usually there is a little picture of how to place the jumpers , if that specific drive has any jumpers ,
Feb 28, 2009 | Maxtor DiamondMax Plus 9 60 GB Hard Drive
New hard drive required for v20
The hard drive that is installed in the V20 laptop is a 30 Gb IDE capacity hard drive.
The smallest IDE hard drive that you can purchase today is in the order of 80 to 100 Gb capacity. The BIOS in the V20 may not be able to support a hard drive this large.
If you install a hard drive of this capacity the BIOS may not detect it or it won't allow you to access the full capacity of the hard drive.
Jan 21, 2009 | Samsung V20 XVC 2400 Notebook
Whats the largest replaement HD I can put in my Presario
The HD capacity is defined by the bios software in the computer, if HP/Compaq tells you that 80Gb is the maximum capacity, then I think you should believe them, after all they should be the first one interested in selling more high price products, go for the 80Gb is .
May 03, 2008 | Computers & Internet
Fquantum fireball lct15 30 gb
After clearing CMOS and it still doesn't work, try to run FDISK on the drive. Delete partitions and create a new one. There could be a hidden partition which could be using the other hard drive space. Restart PC and then format again. This should allow you to use the full hard drive capacity.
Dec 11, 2007 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Compaq (166361-001) Motherboard Logo
769 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
