Question about Emerson CKS2237 Clock Radio
My Clock Gains Time
I have: SN 407030070PH Model # CKS2237 My clock constantly gains time - sometimes as much as 15 or 20 mins. I have moved it near a window and this did not fix the problem. How would you suggest this problem be fixed? Blessings, Brenda.
    Master:
  • 505 Answers
The Clock Is Faulty if you have warranty on it take it back
Posted on Jul 18, 2008
Cloc gains time
well without the make and model number I can only answer generally , most clock radios use the power line to sync the time base (60 hertz=60 seconds = 1 minute=60 minutes=1 hour) , but they use a internal time base generator when running on battery back-up (that's not so accurate) , I had one some time back that a customer plugged into a switched outlet (unknown to them) in there room and it did exactly the same thing it gained about seven minutes every day , me id check the outlet its plugged into to see if its on all the time (a quick test 4 this is to remove battery back up ) clock will then flash to be reset if you come back later to see it when the power was shut off
Jul 26, 2016 | Audio Players & Recorders
Clock gaining time
Sounds like the clock needs replaced...I think it is separate from your radio...try an on-line or local salvage yard first, or talk with a Ford Dealer parts department...hope this helps.
Aug 06, 2015 | 1998 Ford Escort
How to set the clock clock gains time how to correct
You can speed up or slow down the clock by adjusting the length of the pendulum. This link will walk you through the process.
http://usedclockparts.com/9-clock-case-repairs/31-how-to-speed-up-or-slow-down-your-clock-using-it-s-pendulum
Jan 24, 2014 | Home
How do I slow the clock down as it gains time?
the system will need to be sent in for repair
Aug 29, 2012 | Cars & Trucks
Clock not keeping the correct time
I have to ask where you bought the unit? Did it just start doing this or has it done this since new? The reason I ask is if you have a 50 Hz unit and it is operating on 60 Hz it will gain time and there is no adjustment.
Mar 06, 2010 | Miele H344-2 B Stainless Steel Electric...
Digital clock gains time
digital clocks work of the frequency input of the power source so it is possible to have it adjusted by a technician
like fine tuning a radio frequency there may be a pot that can be tuned to mains frequency exactly
talk with technicians in radio or tv shops or possible some jewellers who work on electric clocks may help
Nov 26, 2017 | General Time Corporation Westclox Bell...
Problem with time staying
From Brother Support Website.....
PPF4100 (Clock Gains ½ hour)
The LCD clock on the PPF4100 gains a half hour every 24 hours. Units affected were manufactured between January 2004 and April 2004. The machines manufactured after s/n D4J419125 have the new firmware already installed from the factory.
Machine will need to be taken to a service center and have a firmware upgrade done.
Inkworks
866-381-0541
Nov 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Clock gains 5 minutes or more time over 30-45 days
Could be low-grade electronic components used, less than 1% tolerance values, or the crystal time-base, a precise clock-pulse generator, needs calibration.
Recommend to get it checked by electronics wizard.
Jan 31, 2018 | Aiwa FR-CD1500 Clock Radio
Emerson CKS2237 Clock Radio Logo
254 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
