Check to make sure both battery cables are tight on the battery. Make sure the positive(red) battery cable is tight where it attaches to the starter. The other end of the black cable will be attached to the engine block for ground, check for loose bolt. If everything is tight, look for corrosion damage on the cables. You may need to get under the car to check the wires on the starter to make sure they are all tight. If you don't find any loose wires or cables and the cables and battery are good, then the starter may be going out.
