Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Sears Kenmore Automatic Dishwasher: Models No. 14041 /14045 /14045... Problem:
There is quite of bit of water remaining in the tub of diswasher--this morning it caused water to overflow on my kitchen floor. Troubleshooting in the manual mentioned "Water left in bottom of tub" cleaning the drain air gap. Where is the grain air gap since it is not installed on my counter.
  • 1 more comment
  • igboanugor Jul 06, 2008
    Thanks for Trying: My sink was not capped and my garbage disposal was not on; however my Kenmore Model Nos. are 14041 / 14045 and 14048 Built-in.
    I had put a load in the dishwasher and noticed water coming on my kitchen floor after the dishwasher had completed its entire cycle. Look into dishwasher and noticed the Tub was filled with water.
    Please help!
  • coinop25 Jan 28, 2009
    Exact same issue ... no drain air gap, disposal drain wasn't covered, not sure why water backed up. And now our disposal won't turn on, either.
  • johncarlo2 Apr 25, 2009
    water will not drain even after pushing the cancel/drain button twice--help!
  • 95 Answers
Many dishwasher have their drainlines tied into under sink disposers. If a person caps the sink drain while dishwasher is running, it can back the water back to the washer keeping dishes dirty and backing up water
Posted on Jul 06, 2008
363-1435198 - doesn't fully drain
check your hose going to the disposal. it needs to route up and above the disposal , then loop it back down to the disposal connect. this keeps it from gravity feeding back into your dishwasher. good luck!
Jul 31, 2014 | Kenmore Dishwashers
Our dishwasher is only 4 months old. Sometimes there will be small particles of food left on some of the plates. Also when we wash glasses in this machine they are cloudy or dirty looking.
There are several reasons that the food can be left on the plates. If the washer filter is plugged (partially) then the food particles can remain in the tub and be re-deposited. This can also happen with a dirty sump. According to the specs, your filter is self cleaning, and has a food disposer. The link to your machine is here:
http://www.sears.com/shc/s/p_10153_12605_02213742000P
I think, in your case, a good cleaning would help. When the disposer isn't working well, the screen can be coated, and needs to be cleaned to be efficient. Your manual, accessible from the link above, (then select specifications, scroll down to another link) recommends a vinegar wash and is described there.
For heavy duty cleaning, you can (in this order): Add 1/2 cup of salt, 1 cup of baking soda, and 2 cups of vinegar. Spread the ingredients around the screen, one at a time, at the bottom of the tub. It will begin to foam. When it has quit foaming, add 2 cups of bleach, and run a hot cycle (Pre-heat the water by running the hot water faucet closest to the dishwasher until hot).
Best regards, --W/D--
Feb 12, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
GE Nautilus built-in dishwasher suddenly won't spray
micro switch at the door lock has failed. it just happened to me.
I wired it direct and it worked. just dont open the door until you get a new switch. it wont shut off
Jul 11, 2010 | GE Nautilus 24" Built-in Dishwasher
Kenmore Dishwasher 17372 is leaking water through tub water inlet
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
wqeyrad
Jan 07, 2010 | Kenmore 24 in. 17372 / 17374 / 17379...
Water is leaking from bottom of washer. Product is a Kenmore, Model #110.26752500. Have also noticed that basket inside washer moves quite a bit.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26752500
LEAKING:
See the Sears site sub-components for the agitator, basket and tub. It's possible that one of the gaskets or seals has worn over time.
I'd also pull off the cabinet and check the hoses leading to and from the pump. It's also possible that the pump is leaking.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the basket moves quite a bit more than it should I'd also check the Basket Drive Block to make sure that the "spin tube" is correctly inserted into toe slots on the block and that the "Spanner Nut" is not loose.
I's also check the springs and suspension pads on the Machine Base .
Oct 17, 2009 | Kenmore Washing Machines
Water remains in diswasher
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Aug 13, 2009 | Whirlpool Dishwashers
Some water stays in dishwasher (beau mark portable dishwasher
The manual says that's normal: "A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated."
Dec 14, 2008 | Dishwashers
Diswasher doesn't clean
your water heater is set too low in temp.
you can turn up the heat or get an on demand heater under your sink for the dishwasher. you get a tax rebate too.
the heater in the new washers are too small to effectively heat the water to hot.
and always add a bit of bleach to your wash. the hot water will neutralize it.
or get an old dishwasher.
Mar 24, 2008 | Kenmore Elite 45986 Front Load Washer
Leaky Tub
Are you sure that water leaking out from these two points. If this is the reason for the leaking, it's absolutely a manufacturing problem and you should forward your problem to Sears to take care fot it !! Generally,this problem could be solved by daubing an epoxy glue on the leaking points. Good luck !!
Jun 29, 2006 | Kenmore 24 in. 17019 Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
856 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
