Question about D-Link DI-704P Router
LAN led light alway on and flashing
LAN led light always on even no cable is attached.
LAN led light flashing when a cable is attach but not connected to a computer
what shall i do
  • Tim Babcock
    Tim Babcock May 11, 2010
    Have you held down on the reset burron for 10 seconds to reset it?
    Sergeant:
  • 287 Answers
Reset the router:
While the router is powered on press and hold the reset button for 5-10 sec. Release the button and wait until the router boots up (1 min).
If this does not work then you can try this
Try setting it into recovery mode and loading firmware:
Unplug power cable from the router and press the reset button. While holding the reset button plug the power cable in. Continue holding the reset button untill you will see LEDs on the router flashing rapidly.
You should be able to log into the router - you will see a prompt to load firmware. The firmware is available on our WEB site: http://www.dlink.com.au/tech/
Note - suggest you d/l the firmware BEFORE you reset router
Posted on Jul 06, 2008
MediaPack MP114 - 4FXO Doesn't work
Install wireshark on your PC and connect yoour PC directly to the MP, once there power on the MP and see if any bootp/arp message appears on wireshark if nothing shows up, your device is bricked.
Nov 06, 2013 | AudioCodes MediaPack MP114 - 4FXO
There is a blinking red led light under lower left side of driver and steering wheel attached to dash. It blinks ALWAYs!!!
This is most likely your "Valet" alarm disable switch. Use to disable your car alarm so you can keep your Alarm Fob and let a Valet, mechanic, friend etc. operate the car without the alarm being functional. If it is an after market alarm, consult the mfg's manual, if OEM contact dealer for operating instructions.
Jun 30, 2013 | 2004 Hyundai Tiburon
Can't get my BL-PA300KTA to connect. I have plugged it in and pressed the Setup buttons (within 3 seconds Mater and Terminal). The PC, LAN, and Master lights are ligting up as they should (I believe), with...
I use these and the previous model without any issues.
1. They must be plugged into the wall socket. It's okay to use an extension cord between the adapter and the wall, but never a surge suppressor or UPS
2. The master need to be connected to you router
3. To test your connection do the following
-Plug the master into the wall at the router location
-Plug the slave into the outlet where the computer will be
-Press and hold the setup button on the slave unit only for 3-5 seconds
The leds on the slave will flash for a second or two and then turn solid.
The number of solid lights you see tell you what your connection speed will be 0-no connection, 1-<10MB , 2=-10-30MB, 3->30MB.
I always unplug the ethernet cables from the adapter when testing, but I don't know if that is necessary.
I have never gotten less then 2 leds in my house, but it's new.
Sep 01, 2009 | Panasonic Network Camera HD-PLC Bridge...
I have a toshiba v000108500 motherboard, when lan cable is plug into RJ45 socket, lan work normally, problem is the yellow LED of RJ45 always on (doesn't matter two computers communicate or not), when two...
If you are not having any reception problems to the internet, worry not.
Normal is solid amber, and when it flashes that is a sign of activity on the line. This is not a indicator of a problem or potential problem.
Again if I understand you correctly the local area network is working normally. If this is not the case please write back.
Hope this helps, please leave rating. Thank you kindly
May 07, 2009 | Computers & Internet
Dell Inspiron 1525 with Vista
I'm out for the evening, but I'll be back tomorrow morning. Leave the info and I'll get you a solution.
Jun 20, 2008 | Computers & Internet
Connection Problem
maybe its not in the hub/router, or in your lancard has the problem. try to change the networking cable you are using it sometimes the cable has a teared wire inside, or probably the lancard or your hub does not work for the type of networking cable, there are 2 types of connection for UTP cable first is the Straight through cable and the second is the Cross Over connection. Try to mix and match the cable that you have and try to use another one instead..
Nov 19, 2007 | Cnet CNSH-1600
D-Link DI-704P Router Logo
821 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
