Question about Dishwashers
Asko 3120 dishwasher drain pump keeps running - holding buttons down or disconnecting electrical won't help.
  • 2 more comments
  • Anonymous Mar 14, 2009
    Asko 3120 dishwasher drain pump. Same problem~
    My dishwasher go through the normal circles, the at the end, when it drain, it keep trying to drain, and the motor will not stop. I have to cut the electricity through the breaker. I can not leave it alone, I never know when it will occur.! help
    My dishwasher go through the normal circles, the at the end, when itdrain, it keep trying to drain, and the motor will not stop. I have tocut the electricity through the breaker. I can not leave it alone, Inever know when it will occur.! help
  • gregmetta Apr 02, 2009
    Same problem. Drain motor keeps going, can only stop it by disconnecting electric.
  • Anonymous May 15, 2009
This is because ther is a leak from the main tank. Water goes under the main tank, where all electric motors, pipes an pump are. There is sensor in that area that trigger the drain pump. Up to 4 or 5 liters can accumulate in that area.
Only solution is to remove that water by tilting the washer on what ever corner.
Posted on Dec 05, 2009
  • pc60 Dec 07, 2009
    Under the main tank, there is another storage pan where all the water accumulate.
    Typical reason why water accumulate there is because the washer did not drain properly at previous cycle, hence some water stayed at the bottom of the main tank. On next cycle, the washer starts adding more water, and the overfill trigger, leaking to the under pan.
    After removing all the water, I have observe longer good working time by not using the washer for 24h to let it dry completely. Then it last between 1 to 3 month before I have to clean it again.
    I will update that post if I can find out why the washer does not drain properly.
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
My Asko Dishwasher D1976 on the main panel all of the top lights are on and in the display window it flashes F2. The motor is on but nothing else is happening can you help. I have checked that drains are...
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Apr 22, 2011 | Asko D1976CSTM Built-in Dishwasher
Drain pump won't turn off, all lights are blinking
Try pushing the cancel button. Try holding the cancel button down. If it'll let you select a cycle, try running a cycle. Try putting a large volume of water in there. It might either clear the pump or it will "see" the water going out be satisfied. If it remembers the cycle you last ran, or which cycle you usually run, run a cycle that it's not used to. That helps clear the computer some dishwashers. Failing that, try turning the circuit breaker off for a minute. Press every button on the dishwasher. There's a chance that that will help drain any power stored, making the computer forget what condition it was in. Failing that, try turning the circuit breaker off or for a day or two. Failing that, if you know what you're doing and you're not worried about voiding the warranty, open up the control panel where the main circuit board is. We can assume that if it remembered this cycle with the power turned off for a while that there's a battery in there to keep from clearing the memory. Find the little button cell battery and take it out for a few minutes. Then put it back in and turn the power on. There may a reset button hidden inside there or somewhere else on the machine. Find the manual at home or on the internet and look in the troubleshooting section. There might be a specific button combination to clear that condition.
To keep this from happening in the future, pick up and install a dishwasher air gap for around $15. It's really easy and keeps water from backing up into the dishwasher. They're actually required in a lot of cities.
Sep 15, 2009 | Asko D1706 Built-in Dishwasher
Dishwasher won't power off
Howdy. Flashing light on the switch, shows a glass? At any rate your overflow protection switch is activated. Probable cause; plugged or defective exhaust hose that does not allow pumping to go faster than water coming in, too high a water level. Clean the entire system first!
Is your exhaust hose going up to about threequarters as high as the machine? You must have this uphill twist and turn in the drain system.
A little water remains in the sensor and it thinks you are flooded. Force air through the pump in the floor until all is clear, a clean plumber's helper is ideal. Keep doing this until you get the last bit of water out of the sensor. When you get it running watch the machine (First time) carefully. You do not want a flood, that's why Asko put this safety device in place.
Jul 29, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Jun 22, 2009 | Asko 1375 Dishwasher
ASKO D1986: Water pump running constantly
Solved by draining water from bottom pan.
Jan 18, 2009 | Asko 24 in. D3350 Dishwasher
Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
ASKO Overfill protection tripped
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Dec 31, 2007 | Asko 24 in. D3120 Dishwasher
F2 error message flashes, cannot reset.
Try to find out from where water leaking from (pump or inlet valve). The leaking one, should be replaced. Good luck !
Apr 22, 2007 | Asko D1976 Built-in Dishwasher
Dishwashers Logo
977 people viewed this question
Top Dishwashers Experts
