Question about Philips CDR770 CD Recorder
No disk error
My CD-R Phillips will not reconize any CD-R at the moment I get a no disk message right away . I will buy a cd lens cleaner from radio shack to see if this helps. Hopefully the lens is just dirty.
You have to change the optical laser
Posted on Dec 27, 2008
DIN UNLOCK on the display
The CD isn't reading the disk, so it reports "blank disk". It could be as simple as the CD laser lens having dust or lint on it, in which case you can use a CD cleaner disk (available at Walmart or Radio Shack, Best Buy, etc.). If that doesn't help, the second most common problem is that the laser lens is out of adjustment, and not focusing properly, thus not reading the CD. This can happen with slight wearing of mechanical parts, or any change in the detection circuity (aging of capacitors, etc.) This can be corrected, but it entails taking the unit apart and adjusting the CD lens on a trial and error basis (adjusting, then trying, until you get it right). Here's a web blog on the procedure, and it will clue you in on what you can try. If you don't feel like tackling it yourself, of course, you will have to have the unit serviced. Get an estimate first, since it's also possible that they will just replace parts, or possibly a circuit board, in the event that adjustment of the lens doesn't solve the problem. Here's the blog:
http://www.fixya.com/support/r4192169-fix_calibration_cd_dvd_drive_no_disc
Good luck, and hope this helps!
Jul 22, 2010 | Teac CD-RW880 CD Player / Recorder
I began receiving an error message that says disk read error, the disk is clean no scratches, the door is also fully closed. Any assistance is appreciated
This is a problem with your car cd player correct?
dust often gets in these players and sits on the laser, you might try purchasing a laser lens cleaner at most any store that sells blank cd media.
the disk has small brushes on it that safely brush the dust off from the lens.
Mar 12, 2010 | 1999 Acura TL
CD player in my 2004 Dodge Stratus doesn't work
are they Burned or copied CD's? CDR, CDRW? cause if they are some radios will not read them and give error messages. if not try using a lazer lens cleaner CD, they sell them at most music stores, you may have lint or dust on the CD lens with summer weather, and pollen in the air and dust, CD player lenses take a beating, so get a WET lazer lens CD cleaner, and that should help fix the problem
May 26, 2009 | 2004 Dodge Stratus
Latitude C840 wont reconize optical drive in BIOS
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the the whole drive unit.
Apr 25, 2009 | Dell Latitude C840 24X CD-R W/ DVD Combo...
I have a portable dvd player model number mdp1030 the unit keeps saying no disk I have tried numerous disks same results.
then i think the lens is not able to read the disk.
and so i would suggest you to buy a disk cleaner CD and run it in your DVD player and then use your regular disks.
if this is not working then it is some internal fault in your DVD players lens.
Aug 13, 2008 | Mintek Televison & Video
BOSe Wave Radio - Disk "not readable"
I had the same problem with the disk unreadable error and took my unit to a authorized repair dealer about 100 miles from where I live to have it fixed. It ended up costing me about $300 to have the CD unit totally replaced which is almost as much as I paid for the unit in the first place. I am like a lot of you that used the CD very little although the unit was about 3 years old. I think Bose has a problem and would like us to think it is very rare. I bought a Lifestyle surround system about 14 years ago that has a CD and have never had a problem with it so needless to say I am very disappointed in the Wave II Radio/CD system. I am fairly certain the problem will occur again, but only time will tell.
Mar 03, 2008 | Bose Wave Radio
Xbox 360
I don't see why not, you can buy a special CD that you can use to clean the laser
Nov 11, 2007 | Microsoft Xbox 360 Console
Keeps displaying error cdc
you can try to use a cd lens cleaner CD. Put the lens cleaner in slot 1 and load disk 1 the cleaner shouls be dropped in place and begin to clean the cdrom lens.
Sep 18, 2007 | Cherokee Jeep Grand CD Changers - 10-Disc
Philips CDR770 CD Recorder Logo
184 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
