Question about Denon Audio Players & Recorders
Denon DCD-920 CD Player. Display lights up with a series of 0"s but disc doesn't play
I had exactly the same problem with my Denon DCD-910. Fixing it is easy, but it took me a while to find out;
In the power supply +10V and -10V unstabilized lines (in front of the 7805 and 7905 +5V and -5V regulators on the heatsink),
there are 2 ICP-N15 devices (IC protectors: very fast acting electronic fuses 0.6A). PCB component print is IC502 and IC503 if I remenber well. They tend to deteriorate over time and break, or a current peak could have made them tripping.
The +10V/-10V (+13/-13V really) is used for driving the loading/spindle/sliding motors and focus/tracking coils ONLY. +/-5V was still OK, that's why you can still see the display.
They have a TO92 transistor housing, but only 2 leads. ICP-N15 are hard to find; You could also use ICP-F15, but these have a different housing.
You could order the original ICP-N15 at utsource.net
An alternative could be to mount 2 polyswitches (also called multifuse), a PTC type current limiting and recoverable circuit breaker, like Bourns MF-R065, rated 0.65 A
I replaced them with 2 radial 800mA PCB solder mount fuses (1$/pc), and everything works fine again. Yet another piece of excellent equipment not to be thrown away ;-)
You have to unmount the PCB from the CD player housing (about 8 screws and disconnect all 10 connectors) to be able to replace the fuses.
While it is disassembled, check for broken solderings, especially on high power devices ( like voltage regulators mounted on heatsink or power transistors)
I hope it works for you too.
--Vincent
Posted on Nov 22, 2012
2 Suggested Answers
SOURCE: DENON DCD-825 CD PLAYER stopped playing
Mine did the same and I cleaned the laser lens and it cured it
Posted on Sep 08, 2008
I have a dcd 1650 and it won't read discs, but sometimes it does, I have checked and cleaned lens
A Laser Lens malfunction will cause this to happen and is a common problem. This can be fixed at home if a new Laser Lens or Laser Lens w/ transport can be found for your unit. I used ebay to purchase a new Laser Lens for my Denon DVD 5900. The part is also sometimes available from parts stores like Parts Express for a premium, $100+ Parts Express vs $17 ebay in my case. I would recommend purchasing a FACTORY SERVICE MANUAL from an online vendor. The manual will cost between $10 - $20 and is downloadable. The installation is very straight forward. The part that might not be clear would be the grounding shorts on the new Laser Lens. THE NEW LENS COMES SHORTED AND AFTER THE PART IS INSTALLED IN THE PLAYER THE GROUND SHORTS MUST BE UNSOLDERD FOR IT TO WORK CORECTLY. The part comes this way to protect the Laser from static shock damage.
The repair on a Denon DVD 5900 cost $30 and took about an hour to complete.
Jan 07, 2013 | Denon DCD-1650 CD Player
I have a Denon dcd 600 cd player. Old but little used and in good condition. Used to put in a cd, close the drawer and the entire display would light up, the disc having not been read at all. After...
it's most likely the belt that drives the cd tray has perished over time and certainly if you tilt the player to help it, that's just gravity giving it a push. replace the belt and all should be ok. hope this helps?
Jan 06, 2010 | Denon DCD-425 CD Player
Denon Amp (PMA-700AE) ignores the signal from CD Player DCD-700
If you can follow the circuit from the input of the cd play socket inside the amp itself you might come accross a Memory Retention Capacitor that supplies an IC. If you do. I can't for certain say one will be there, I would replace it, it might be the cause of the lost memory of your device.
If you don't know what a M R C looks like, they are like electrolytic types, but haven the appearance of being squashed. The value will be low only 0.22uf etc and the volts very low say 5.5. The PC board marking will be different to a normal capictor.
Nov 14, 2009 | Audio Players & Recorders
Denon CD player DCD 920. When using the open/close button once, the CD-door opens but when it is open, without any waiting time, it immediately closes again. If i operate manually the open/close switch on...
Off the power, and plug off the switch, and try opening it manually. DO NOT force open it. I don't think it would close back since it has no electricity already.
Oct 14, 2009 | Denon Audio Players & Recorders
Have a Denon DCD-520 and it skips forward and back while playing
Hopefully, it may just need cleaning and lube.
I have a Denon DCM-460 purchased from Goodwill a couple days ago and had problem with one CD-R skipping and stuttering toward the end.
Cleaned the CD which helped a little but still started skipping and stuttering.
Noticed a scratch toward the outer end which I suspect is where the problems occurred.
Anyway, last night I cleaned laser, rails, lubed spindles and moving parts. I used 99.9% alcohol to clean. I used a light teflon oil (Tri-Flow) to lube spindles and rails. And white electronic grease where you see remnants of white grease.
Today, I now played through the problem CD-R with no problems.
Assuming placement is level and stable, certainly worth a try and the effort.
Feb 01, 2009 | Audio Players & Recorders
Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Nov 28, 2008 | Denon Dns1000 Table Top CD Player CD...
500 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
