Question about Gateway FPD1950
Monitor screen displays sideways
For some unknown reason, my Gateway FPD 1950 Monitor is displyaing sideways. In order to view anything, we have to turn our heads to the right. Please help. How do we fix?
  • 983 Answers
If the screen is rotated then press
ctrl + alt + up arrow
your screen will be placed correctly
this is happened because sometime you might have pressed by mistake ctrl + alt + some arrow key .....
the hot key will be enabled defaultly so your screen got rotated
Posted on Jul 06, 2008
You helped me to resolve this issue yesterday.
thank you.
Gateway fpd 2485 W looked like 60 cycle lines across
Power supply will be the first thing to check, see example of failed Gateway due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 18, 2010 | Gateway FPD1975W 19" LCD Monitor
Message from display FPD 1730 won't go away
press the menu button on screen panel and press exit.
Dec 02, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway monitor FPD 1730: We have had it since
If the screen is black (ie there isn't any backlight) then the fault maybe the inverter board that supplies high voltage to the CCFL lamp ot the CCFL lamp is faulty.
For service, parts and DIY info. check out LCD Parts - use this link to their WEB site.
www.lcdparts.net
Sep 28, 2009 | Computers & Internet
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Monitor goes blank
I was thinking about your problem, I just had a similar issue and the problem is that the inverter or the power supply with an embedded inverter had gone bad.
The reason it goes black is because the inverter fails to provide power to the LCD Display.
The only way to fix this is to open up the FPD:
*note these are instructions for the most popular FPD 1730*
1.there should be four screws on the back --> plus two large screws that hold the FPD stand and the Monitor together.
2.Open the back by pulling the cover off
Remove 7 screws holding the frame and the power button for the LCD
3.Remove two screws through holding a silver cover and remove cables.(pinkwhite) (blackwhite)
Please note where they belong before removal**
4.On the edges left and right are two screws 4 total ---> remove and remove LCD off of frame**becareful because the backlight Damaging can cause severe damage to your LCD panel.
5.Choose your model
Your FPD has 3 boards (power, inverter(backlights) Logic Video)
replace the inverter with well known good one
Your FPD has 2 boards(Power with inverter on edges, Logic Video)
replace the power board with a well known good one
6.Then do steps 1-5 in reverse order(putting your FPD back together.
I hope this is significant help
Sep 11, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Dark screen of Gateway FPD 1520
If you can see the screen display an image upon close scrutiny, it could be that the florescent back light is burned out.
Aug 03, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Gateway monitor model Fpd 1950
It's probably cheaper to get a new monitor than it is to get a logic board. If Gateway can even get you such a thing.
Good luck on that.
Jun 15, 2008 | Gateway FPD1950
Gateway FPD1950 Logo
1,020 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
