Question about Medion Computers & Internet
I WANT TO REPLACE MY RAM MEMORY TO UPGRADE TO 2GB
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    Or at the very least the model of the Medion computer.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Do you know the make and model of the motherboard?
  • 47 Answers
Hai,remove ram and replace the sam ram (ex,DDR,SD-RAM).start the processor .
Posted on Jul 06, 2008
I upgraded Memory to 4GB with Two 2GB SD Ram Modules but System shows Only One 2GB module and does not show/recognize second module. BIOS Setting Shows Second Slot/RAM Module Not Activated.
is the module in properly?,is anything broken?? switch them around and see if the module is good or not,also,just because the motherboard supports 2 modules,if intel only recognizes 2gb then that is all,whether you have 2 1gb modules or 2 2gb modules,upgrade your intel chip and upgrade your bios
May 21, 2015 | Computers & Internet
I put a 2gb ddr2-667 memory chip in the single (only) memory slot in my gateway nx100x notebook pc. The pc will not boot up with the 2gb memory card. Is there a compatibility problem or do I have a ba
yes, there may be compatibility problem. your 2GB ram may be dead. try your 2gb ram on other notebooks. if it is working on other notebooks, then your ram is ok. your notebook will support maximum 2GB ddr2 memory per slot. your notebook may not be booting due to unsupported frequency of your ram. maximum supported frequency for your notebook may me 400Mhz, and you are putting a 667MHz ram into it. try to put a 400MHz 2GB ddr2 ram in your notebook.
Apr 10, 2013 | Gateway Computers & Internet
How to replace RAM in Satellite M45-S165
http://www.irisvista.com/tech/laptops/ToshibaM45/Satellite_M45_disassembly_1.htm
You can click on any photo to enlarge it.
Step 3 photo shows the Memory Compartment.
Two ram memory (SO-DIMM) can be used. There are two ram memory slots.
1GB however, IS the largest amount for EACH slot.
Regards,
joecoolvette
Apr 14, 2012 | Toshiba Satellite M45-S165 Notebook
My laptop is too slow even if i am just surfing internet like FB. can the memory be upgradable? up to how many gb?
you can upgrade up to 2GB (DDR2)
Your computer has 1 memory slot you remove the memory and install a new one.
you can use either
2GB 800MHz DDR2 Non-ECC CL6 SO DIMM
or
2GB 667MHz DDR2 Non-ECC CL6 SO DIMM
Jun 22, 2011 | ASUS Eee PC 1000H Laptop
Samsung n150 plus is expandable to how many memory?
The Samsung N150 Laptop comes installed with 1GB of Memory and can be upgraded to a maximum of 2GB Memory. This computer has 1 (one) SO-DIMM memory slot, so to upgrade to 2GB of RAM, you will need to replace the installed RAM module with a single 2GB PC2-5300 DDR2-667 200pin SDRAM SO-DIMM memory module.
If you find this solution helpful, please leave a positive rating!
Jun 21, 2011 | Samsung N150 Notebook
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | Compaq Presario Notebook
I have hp dv-1000 laptop with 256 ram, which i wud like to upgrade to maximum.so how many GB ram i can go for and what wud be the price.?Can i go for 4GB ram?
You can upgrade to 2Gb ram. I dont think your notebook will support 4Gb ram. A 2Gb Transcend ram will cost you around 1500 bucks INR
Sep 01, 2009 | HP Pavilion dv1000 Notebook
How much ram does asrock p4i45gv support?what is the maximum ram capacity i can upgrade to???
- 2 x DDR slots, DDR333/266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Jul 07, 2009 | Asrock P4I45GV R5 Motherboard
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
What kind of ram?
just look for notebook memory type ddr2, ddr2 all have the same amout of pins, you will have to remove one of the sticks of ram and replace with a 1GB or remove both and fit 2 x 1GB sticks.
seee below
http://www.ebuyer.com/store/Components/cat/Memory---Laptop
Nov 23, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
49 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
