Question about Refrigerators
Whirpool conquest refrigerator-about 8 years old-not cold enough
Is there a history with this model,because this is the second time this refrigerator basically doesnt cool on both sides.the foodis defrosting on the freezer and the fridge is making my food spoil.the motor runs and i can see the fan working in the back where the condensor is.i had the temp setting on half way for both sides,but even when i set it to max. it doesnt cool at all!
theres no frosting that i can see.so im thinking then that its something to do with the thermostat?
is that right?
would it be then the defrost timer,fridge thermostat,or a defective temp. control?
what do you think?
  • Anonymous Apr 25, 2009
    I have the same problem with my Conquest. Milk is always going back.
  • 481 Answers
  • if it does not cool at all then i would suspect the start switch on the side of the compressor or the compressor itself.
  • if the previous repair included tapping into the freon line then it could be the freon leaked out.
  • if the thermostat was bad then the refrigerator fans would not be running,
  • and if the defrost timer was bad (stuck in defrost = not cooling) then the fans would not be running.
  • i don't know of any bad history with this particular model
  • double check the back wall of the freezer to make sure there is no buildup of frost, because this would be a defrost issue.
  • if it is getting a little cold but not cold enough then let me know the temps
Posted on Jul 06, 2008
My whirpool fridge about 3 years old Whirpool model GX5FHDXVY00 the fridge is getting warm all the time, call up a tech and he has no idea what's wrong. I have to sometime manually defrost, unplug so...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 14, 2011 | Whirlpool GX5FHDXVY Stainless Steel (248...
Whirpool gold
I did some research online, and read that the Start Relay is most commonly the problem. My husband bought the part, (about $50) and reattached it to the side of the compressor....and was cold immediately! apparently a very common problem on these fridges.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Conquest water filter in my whirpool side by side
yes it is. as long as there is still water coming out from the dispenser.
the red light only indicates that it is about time to replace the filter. could be 6 months old. this is controlled by time, so check your water pressure at the dispenser, if it is still strong, then you could still use it .
depending on your condition, some filters would be clogged already even if the light is still green and there is no more water coming out of your dispenser.
normal time to replace the filter is six months.
tnx 4 using fixya,
drcool
Oct 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker is not working
hi. thanks for the question. because the door was left open . moisture got into the small tube that lets water in to the ice maker.. and froze. use hair dryer to thaw the tube. remove and clean. thanks the appliance doc. please rate me
Sep 11, 2008 | Whirlpool GD2SHGX Refrigerator
10 year old Whirpool Top Load washer
hi thanks for the question the problem you have is with a part called drive coupling which is situated on the motor and transmission replace this part thanks te appliance doc
Aug 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirpool refrigerator, freezer fine, refrigerator warm
my suggestion give it up for the dead
Feb 23, 2008 | Refrigerators
Refrigerators Logo
147 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
