Question about Hitachi 53UDX10B 53" Rear Projection Television
TV Troubleshooting Hi my name is Jose .I Have a Cable services on my TV becouse I did not oay on Time they turn off the box My TV turns off to .I can'nt turn back on antill they turn the box back on .but all the colors were mess up especialy the red color is way out the line
  • 927 Answers
Good Day Joseamunoz2;
It sounds like the convergence circuit has failed, but it does not normally cause the TV not to turn on. Until you get a signal (cable) back on, double check your concerns.
Good Luck, big IRISH.
Posted on Aug 25, 2008
Television say check signal cable . I have a scientific atlanta cable box.What do I do?
How is the TV connected to the cable box (HDMI, component video, etc.)? Make sure that the cables are securely connected and that the TV is on the correct input. Try swapping the current cables for new ones. (The HDMI cable has come loose on my entertainment system at times.) If you route HDMI cables via a sound receiver (cable box -> receiver -> TV), try a direct connection to the TV.
For my TV, I have to turn on one set-top box before I turn on the TV to get the signals to correctly synchronize. (Try turning off everything connected to the TV and then turn on the accessories first. Then turn on the TV.) For another set-top box, it needs to be turned on before the TV. (So try both options.)
Make sure that your set-top box is on and try a different TV or input if possible. If a second TV doesn't work with the box, contact the provider and check for a service outage. (Also try a different set-top box (like a blu-ray player) to check if it is the input on the TV.)
Note: I've had mice or other things damage wiring; this takes out the cable and phone lines. If this is outside damage, your service provider should repair the damage for free.
I hope this helps. Please add a comment with more information about your TV and the connections that you are using for additional support.
Apr 25, 2013 | Televison & Video
Hitachi 51F710E has no sound
The audio portion of the main board is failing. You can get a replacement here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 07, 2017 | Hitachi 51F710 Rear Projection Television
Shortly after turning on my 2007 samsung 42" LCD TV, the sound turns off.
Since you just changed signal source (from what I understand) your first goal should be to determine if the problem is in your TV or your signal source, i.e. directv receiver (and btw aren't directv satellite and not cable service?!).
You do that by trying another source for the TV - DVD, blue-ray, over-the-air antenna, anything that is not your new sound source.
Once you know the sound is broken down by the TV and not the TV receiver (or the other way around) you can proceed with troubleshooting.
Oct 22, 2011 | Televison & Video
When tv is turned on, screen shows white w/ blue logo, then shows "VGA" and "no signal" on a blue screen. After a minute it turns off. We cannot get a picture. We have a Time Warner...
Right now the TV is set to accept the video signal from PC through the VGA port so when it does not see the video signal from the VGA port, the TV will go into shutdown or standby mode. You need to change the input to be where the cable box is connected to using INPUT or SOURCE button on the remote.
What kind of connection are you using to make the connection between the TV and the cable box?
Please clarify. Make and model of the TV?
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Aug 19, 2011 | Televison & Video
How do i connect sanyo 1600 to cable box and tv.
Hi my name is John. Welcome to FixYa. Run a cable jumper from the TV to output of the cable box, then run the cable to the input of the cable box. You may have to turn TV to AUX. Thanks for choosing FixYa...John
Dec 03, 2010 | Sanyo DVW-6100 DVD Player/VCR
Sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
My 27" wega was making a crackling noise when I turned it on. Last time I turned it on it made a pop and went to standby, it blinks three times, pauses then blinks again clicks and blinks four times.
pls. check your tv mains plugh is luss canaction
if not then
probulum is in side tv set so pls. dont.use tv again and cont.nearest tv tech.and solve this problum. becous cracking noise is dengered for your tv.set
* you dont. open tv back cover it your self.becous in side tv set very high voltage.
Nov 10, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
I need ATT uverse remote control code for Onkyo AV rec TXSR304
hi just a tip! try to program your remote to control both your tv and the cable box both at the same time so when you try to adjust the volume automatically both tv and the cable box will respond. you can actually call uverse for that so that they can assist you on programming your remote to your tv and cable box. hope this would help goodluck!!!
Jan 04, 2009 | Durabrand DWT1304 13" TV
Samsung Rear Projection DLP HDMI Captions
The captions are turned on in the cable box itself. If you have a Motorola cable box, turn it off then hit the menu button for the cable box. You will then see where you can turn off the closed captioning. Anymore questions email me tvtek@msn.com
Nov 29, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Philips 50 inch Plasma - no audio on occasion
Try swapping the HDMI cable. They occassionally fail.
Nov 21, 2007 | Philips 50PF9630A 50 in. Plasma Television
Hitachi 53UDX10B 53" Rear Projection Television Logo
29 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
