Question about Oreck XL2200 Bagged Upright Vacuum
Motor and Lights stopped suddenly after vacuuming the stairs.
I was vacuuming the stairs, and all of a sudden the light went out and the motor stopped. Is it possible to overheat it, or blow a fuse?
Thanks,
Brigham
  • Brigham81 Jul 07, 2008
    I did call Orek customer service. I was hoping they could walk me thru a procedure, but all they really did was tell me the closest Oreck dealer.
    It turns out there was a vacuum repair dealer less than a mile from my house. He took a look at the machine, and then said that we had knocked a wire loose inside when we were trouble shooting it. Good as new!
  • Anonymous Nov 11, 2008
    Vacuum stopped in the middle of vacuuming. No motor or lights working
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=19809&thid=745467
Motor and Lights stopped suddenly after vacuuming...
Posted by Brigham81 on Jul 05, 2008
I was vacuuming the stairs, and all of a sudden the light went out and the motor stopped. Is it possible to overheat it, or blow a fuse? Thanks, Brigham
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL2200 Bagged Upright Vacuum. It sounds to me that when the lights go out and it stops working that the motor is bad that you would have to replace the motor. It is still cheaper to replace the motor than to purchase a new vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 07, 2008
It was working fine and then all of a sudden stopped. The power switch still lights up but the motor doesn't run. What could be wrong?
you didn't state your model so I can't be specific to your model. It could be a loose wire, reset switch, bad motor, worn motor brushes, fuse, switch, etc.
You'll have to check to insure power is making it to the motor and if so why the motor isn't running.
May 01, 2016 | Vacuums
Stanley 3.5 wet/dry vacuum motor runs but suddenly suction stopped just like it does when tipped over, but didn't tip over
ck ball that saves the motor when container gets full of water , they sometimes get stuck inside the little cage there in an shut off suction
Jan 19, 2016 | Stanley 3.5-Gal. Wet/Dry Vacuum
Why is my vacuum cleaner all of a sudden shutting off on it's own
Depends on the type of vacuum but the motor could be over heating check all filters and clean them to get better air flow to the motor
Jul 10, 2013 | Dirt Devil Vacuums
I was vacuuming with my DC28 Animal and all fo a sudden the beater bar stopped working and NONE of the floor mode buttons work.. no lights or anyhting. I checked for obstructions per the Dyson manua
Check the wire connection that feeds that section. to make sure it is being supplied power. Since motor is also not working it has to be something they all have in common -POWER!
Sep 06, 2017 | Dyson DC28 Animal Bagless Upright Vacuum
It suddenly stop working but the light is still on. my vac. model is 116.30201500c, serial no. M51801511
The fuse is blown. It's located near the motor. One side of the fuse goes to the on/off swith and the other end to the motor.
Apr 26, 2011 | Kenmore Vacuums
My motor stop all of a sudden. What is wrong with it?
The motor brushes are worn out...shorting the motor, hence it will not start. The part is only 75¢ - unfortunately it'll cost you around $45 to have it fixed...just look for a local Panasonic or Sharp dealer. Good Luck!
Dec 29, 2009 | Panasonic MC-V7305 Upright Vacuum
I have aeureka 450, it stops suddenly when I vacuum? HELP
the motor is probably overheating. you will probably have to replace the motor.
Apr 04, 2009 | Eureka Whirlwind Litespeed 5740 Bagless...
Vacuum won't turn on
there is an overheat stat which turns motor off. possible cause is filters blocked or a blockage elsewhere - no air flow and the motor overheats
Mar 26, 2007 | Bosch Cyclone Jet Upright Vacuum
Oreck XL2200 Bagged Upright Vacuum Logo
941 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
