Question about Acer Aspire 5315 Notebook
CPU change Can you upgrade the cpu to a faster one than the 1.86 Celeron that comes in the Aspire 5315-2940, I know its not soldered in.
    Problem Solver:
  • 13 Answers
You can upgrade to a T8300 CORE2DUO
check my info... i have upgraded 3 aspire 5315s
http://forum.notebookreview.com/showthread.php?t=251959
bigO has the info
BTW i am the infamous bigozone aka bigO
google "ASPIRE 5315 CPU UPGRADE"
Posted on Jul 12, 2008
  • 2,794 Answers
You might be able to get a faster Celeron to fit that socket however you have to make sure the heat sink will work and that it will not overheat the unit.
You might get away with 2 ghz but anything bigger than that might cause a problem.
Posted on Jul 05, 2008
E5-515 upgrade to faster cpu
Review laptop specs from Aspire website. May require new motherboard. Costly upgrade! CPU may not be plug in style, most Aspire CPUs are soldered in.
Aug 24, 2014 | Acer Aspire Computers & Internet
Celeron 540 upgrade
Aspire 4315 Specifications Specifications
Part Number
Varies by specifications
Processor / Speed
Intel Celeron mobile processor 530/540/550 (1 MB L2 cache, 1.73/1.86/2 GHz, 533 MHz FSB), supporting Intel 64 architecture
if you have a 2 Ghz processor installed, you will have to replace the motherboard to go with a faster CPU.. which will be spendy..
Hope this helps
May 06, 2009 | Acer Aspire 4315 Notebook
I have an intel celeron 1.79 GHZ on my dimension 2350,what is the better processor for upgrade? and is there something else that i should change inside for the new processor?
you said that you want to upgrade ur 1.79ghz celeron cpu.
to upgrade a cpu just check that the packaging of the new cpu matches with the motherboard.
and also check that the motherboard supports the new cpu that you are installing. check this in the manufactures site.
Apr 14, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Intel Celeron Upgrade
I know how you feel, you want to improve your situation but not spend a lot of money, and squeeze some more out of what you already bought. You have a latop that works, no need to get rid of it. The problem is that CPUs on laptops are really not made to upgrade. The overwhelming amount of data out there tell us that it's actually just easier and sensible to buy a new one. I know that's not what you want to hear, but- 1) celeron chips are really not designed for gaming, although that doesnt mean you can play simple games on them 2) if your chip is a celeron, it means your laptop was not a high-end one that had the pentium chip plus all the other higher-end (faster) components that support it. That means that even if you bump up your celeron to one a bit faster, it will still have all the slow components around it. 3) the motherboard limits what you can do-- it will not let you upgrade to the fastest celeron out there, but will allow you to upgrade withing a narrow range of celerons. This is because as chips get faster, the companies change the way they attach to the motherboard, and newer chips dont attach to older montherboards. 4) the main determinant of gaming is your graphics card, then RAM, and these wont be affected by upgrading your CPU. 5) even if you were to replace your celeron, you'd have to pay a decent ammount for it, maybe 100 bucks, and I've seen new laptops sell for 399 to 499 entry level. For me, I'd rather scrape up the extra 300 bucks and just get a new laptop, which will have the new CPU (much faster than the fastest celeron), new graphics card, probably much more ram than your system can now support. Don't mean to rain on your parade! Good luck.
Feb 01, 2009 | Intel Celeron D 335, 2.8 GHz Processor
REPLACE FAULTY CPU CELERON 3.06GHZ WITH PENTIUM 4 CPU
Your motherboard specs are at http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000152
Looks like you could go up to a 3.8GHz P4, make sure you get a fan that will cool it properly.
Dec 28, 2008 | Foxconn 661FX7MF-S Motherboard
Cpu upgrade
Upgrading the CPU in a notebook is a bad idea.
Even if you get a compatible CPU, a faster processor means more heat, and notebooks are not design to handle it. You would risk major damage.
If you want to make it faster, try increasing the memory.
Dec 14, 2008 | Ashton Digital Passport 2068 Notebook
Toshiba a30-931 what is largest posible cpu
Franky_J knows nothing you could go for a P4 2.8 cpu which would work much better than the Celeron in fack any P4 over 2.0 would out perform the celeron if you want speed get rid of the Celeron and get a P4 it should take up to an 3.2 P4 chip.
Franky if you dont understand cpu's then you shouldn't really be answering this question in the cpu world a 2.8 ghz cpu is not always a 2.8ghz cpu for instance this one has half the cash of a P4 cpu meaning it can only do half the work at the same time so in P4 terms this is only a 1.8 P4 equivilent so a 2.8 P4 will be a big improvement.
Nov 25, 2008 | Toshiba Pentium 4, 2.88 GHz (P000382340)...
Cpu upgrade for hp 530 laptop
the chip is soldered to the motherboard an i would not mess with that u will end up with a paper weight
Jun 25, 2008 | HP 530 Notebook PC
Upgrade the processor on a Toshiba equium l40 series from a celron M
The core2 duo chips will be a different socket to your celeron cpu so can do that unfortunately. You may be able to upgrade to a faster cpu of the same socket type but will probably need a bios update for it to run at proper speed.
Unfortunately laptops arent really designed to be upgraded at all bar extra ram/hd/dvdrw.
Hope that helps?
Dec 26, 2007 | Toshiba Celeron, 2.50 GHz (P000396980)...
Acer Aspire 5315 Notebook Logo
515 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
