Hard Drive Installation
I have a SATA 500 GB Hard drive and I would like to install it into my Dell Dimension 2400 computer. Is this going to be possible
    President:
  • 1,314 Answers
The Dimension 2400 does not have SATA ports. Therefore, you need to purchase a SATA card to do this. Something just like this.
Posted on Jul 05, 2008
Have a used dell dimension 2400, hard drive died i replaced it, but i dont have the original os disc that came with the system, can i use my copy of vista, or find another copy
If your Dell computer had Vista installed then you can use your copy of Vista CD and you can use the product installation code that is printed on the Windows label that is attached to your Dell.
When you insert the Windows CD into your Dell and boot up your computer then select the CD as the boot device (ie 4=IDE CD).
After Windows is installed and activated then you need to install the Dell computer's device drivers.
You can download the device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Jan 21, 2013 | Dell Dimension 2400 PC Desktop
I have a PC Dell Dimension 2400 with a hard 40 GB
Basically when you install a new boot drive you need to install Windows operating system on the new hard drive, also the device drivers (eg video, audio, modem, LAN etc), your programs and data. The reason programs has to be installed is because the installation process copied DLL files to the System folders and makes changes to the registry.
You can only copy your data onto the new hard disk.
To avoid copying your data to the new hard drive, you can set up the old hard drive as second hard drive (ie. slave drive), if you delete the redundant folders and leave only the data folders then you have an adddition 40Gb of disk space.
Aug 27, 2009 | Dell Dimension 2400 PC Desktop
I replaced a bad 120 gb hard drive with a WD 500gb sata hard drive. Installation went fine, however I am having trouble with the reinstall of the XP system. It freezes up at the point where it asks if you...
First, I would remove the 120 from the system during installation. If possible, use a Windows XP disc w/ SP2 to speed up installation of the OS. Plus SP2 handles a maximum disk size error which limits you maximum partition size. (Under SP1 I think the largest partition can be 137 MB)
I would recommend using NTFS format for the hard drive.
Once it is installed, you can always re-connect it to simplify the installation.
If it's still freezing, check the disc for damage or defects.
Dec 31, 2008 | Dell Dimension 2400 PC Desktop
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
How to install new HD w/o a floppy?
Your computer should be able to handle either the 120 or 150 replacement drive. Most drives today come ready to load. Your Dell installation disk would be the best bet to install everything on the new drive. The restore disk will look for existing software and not find it. The other thing you might want to try is once you get the new disk up and running, change the pin setting on the second drive to be a slave drive and your new drive to a master with slave, and try to recover your data. If you don't have the dell install disk, a copy of Windows will also do the trick. No you don't need a floppy unless you plan on reformatting the new drive.
Hope this helps
Mark
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
RE: Dell Dimension 2400
Tiger is really great; I use their sister company as my distributor for my pc sales business. The only other determining factor is the size of the hard drive. $60 can get you 200 GB, but $100 can get you 500 GB. It all depends on how much you need. Glad I could be of help. Thanks and please take a moment to rate as fixya.
Jul 13, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 with secondary SATA hard drive keeps crashing
generally all computers can handle a secondary hard drive. i myself am a dell tech. why not try to increase the wattage output of your power supply from the present 200 or 250 watts to at least 300 or 350 watts to give enough provisions for additional devices that will be connected to your computer. normally a hard drive will get burned or fried because of a loose power cable connection. data cable will never fry your hard drive. try running the hard drive diagnostics if it passes then it should work well. try also using chkdsk /r in the command prompt to fix your hard drive if the damage is not that extensive.
Jun 20, 2008 | Dell Dimension 2400 PC Desktop
Help my second hard drive dont show up
Hi
Make sure it is connected properly.
Then go to Disk Management by typing "diskmgmt.msc" in the Run window.
Then check in Disk Management if there is any unassigned or any uninitialised partition there.
If you find one, right click on it and then select either "Format" or "Initialise".
Mar 05, 2008 | Computers & Internet
Hard drive installation
You should be able to install that drive. The biggest variable is if it is a SATA or PATA drive. This model was built for SATA drives, but I think you may be able to get a PATA drive to work with the right adapters.
For the step by stem directions see the link below. It will take you right to the Dell support page. Refer to the "Adding a Second Hard Drive" section.
https://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1366406
Feb 21, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
you need to turn it on in the Bios so the computer sees the drive, then format it.
Jan 20, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
