Keyboards come in several layouts and you have to go to the control panel , keyboard and select the layout that suits you
in the details , advanced section you will find driver update
make sure that it is correct
have to installed the small dongle into a usb port for the keyboard and mouse
did you put batteries correctly into the mouse
I had the same problem and reinstalling the drivers worked for me.
To remove and then reinstall the drivers, follow these steps:
1.Disconnect the device from the computer.
2.Turn off the power for the device, if the device has a separate power supply.
3.Open Device Manager. To do this, use one of the following methods:
In Windows Vista or Windows 7, click StartStart button , type device in the Start Search box, and then click Device Manager in the Programs list. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
4.In Windows XP, click Start, click Run, type devmgmt.msc, and then click OK.
5.Double-click Keyboard, right-click the keyboard that you use, and then click Uninstall.
If your device is not listed:
1.Restart the computer.
2.First, turn on the device, if you have to, and then plug the device into the computer. Your computer detects the device and then reinstalls the drivers for the device.
SOURCE: logitech ex 100 mouse doesn't work
Normal
0
Turn the mouse over and find the small
rest/connect button on the bottom of the mouse and press it to
Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press
the mouse. This should be done whenever you change batteries or
glitch.
Hope this helps you. Bud
SOURCE: logitech easycall mouse works but the keyboard will not
I had the same problem. Some keys on the keyboard would work, others not. It seemed to happen after an update to the SetPoint software. I got it fixed! I tried everything and in the end this is what worked:
1. I started the computer and obviously could not log in.
2. My mouse worked, my standby key worked, but no other keys.
3. I used the mouse to activate the on-board keyboard in Vista (left bottom corner).
4. I put in my password and logged in.
5. I opened up an app (Excel in my case) to try to type something in.
6. As soon as I hit a key a Logitech wizard for encrypted communication came up!!! It asked me to press the connect button and then enter a code it displayed (keyboard worked at this point).
From this point on the keyboard worked!!
Note to Logitech.... great job on the extra security... bad job on the implementation... if your wizard runs after a PC is rebooted that has login passowrd protection.... how are the users supposed to log in??
Note: My logitech upgrade hung... with mouse and keyboard becoming unresponsive so I had to do the hard power off... maybe the wizard was meant to run after the upgrade before I had to force a restart, but this is something that should be taken into account as well.
SOURCE: My Logitech EX 100 keyboard and mouse combo doesn't work
Make sure the batteries work by testing them in another device(sometimes they lose their charge if they have been in the box too long). If they are charged, make sure you have the devices connected directly to the computers onboard USB port so that you can be sure it is getting enough power to the reciever.
If this does not work, it might be a hardware setting on windows. You will want to make sure all of your drivers are installed properly in device manager, this is unlikly the problem but it has been known to happen. Make sure the mouse and keyboard are aligned properly with the reciever.
If your computer is running slow, it may just take a long time for windows to recognize the new device. If you do not hear windows responding by making the 'new device found' sound then it probably is not detecting the new device in which case it is probably something wrong with windows or the drivers. If it does make the sound and it says it is loading and you see the ballons pop up on the bottom right then it has sucessfully connected.
If all of this does not work, then I would say that they are toast. Try them on a different computer if you can. This should give you a definate idea of if it is a problem with your computer or a problem with the device itself.
SOURCE: The mouse does not work
Change the batteries. If still a problem, try the mouse on another workstation. If it still doesn't work, it will confirm that the mouse or USB receiver is faulty.
