Question about Philips Magnavox 51MP392H Rear Projection Television
55p8288 46" Magnovox
I have taken the button part out and tried soldering the spot right behind where the button hits. Is this the right spot ?Where ther are numbers labeling the spot. I am using a magnifying glass.
Thanks
  • 2,071 Answers
In the circuit board labelled "power on"it is a tacking change that switch.
Posted on Jul 06, 2008
Where is the inertia switch in a 1999 forc courier
Were you in an accident? I have reset some, but never run into a bad switch. Ford puts them in three spots, that I have found. All on the passenger side. Behind the kick panel to the right of the passengers foot. There is a hole in the panel to insert a finger to reset. Next is under the rear dash panel, in the trunk. then in the trunk also, behind the carpet, near the rear lights, some have holes, some don't.
Nov 28, 2015 | Ford Cars & Trucks
Model 55p8288
maybe the push button switch is defected ,the solder of the switch is brittle , or crack or cold,try to resolder the switch, if not change it with new one.I incounter like this problem before in the switch , i only resolder the joint then its ok,,try this also maybe can help...
Jul 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
I have a magnovox TB110mw9 reciever that the audio button on remote does not work. it is hooked to a magnovox 20mt1331/17 tv. we have a RCA universal 4 device remote programmed to both. my 2 year old...
Universals do not do specific buttons like the AUDIO button on your Magnavox. Instead of wasting up to $20 on a universal that probably will not work, you should by the original remote for whatever it costs, because you know it will do all the features for your Magnavox unit that it has to offer. Many times ReplacementRemotes.com will get Refurbished remote available for really cheap. LIke $10 - $15. You can subscribe to the product so next time they get one in, the site will notify you immediately that they are in-stock.
Oct 18, 2013 | Televison & Video
I have a Magnovox HD1905C121 television. I somehow
Hi M beswick,
I need some information so that I can better answer your question.
1. Are you using direct cable from the wall, cable box, satellite?2. Please let me know what will be the display if you hit the menu button at the front panel or on the remote control.
Jdvillanueva
Oct 21, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I need to place a wire on a push button switch for a computer that has 6 poles. Of the red and white wires, the red one is soldered to the bottom right pole. The white one came off and I don't see an...
Im not sure what your switch looks like, however you could hold the wire on each post and hit the switch and see if it works. If not try putting it on another spot and try again. You wont short anything out or anything like that. It just will or wont work. This is how you can tell which spot the wire should be on.
May 20, 2010 | HP Compaq Presario S6100NX PC Desktop
Dvd recorded on magnovox won't play on toshiba
My Nexxtech want play. It seems to go right back to stop. Does the battery pack need to be fully charged before I play a movie?
Oct 04, 2009 | Televison & Video
GTS22KBMBRWW GE refrigerator; the compresser does not come on, no indicator light for freezer compartment. Indicator light on for the bottom section.
Due to the compressor not coming on , this is an indication of a bad main control board . Part number WR55X10942 . Occasionally , if you remove the board ( behind the 8"X10" panel , on the back of the refrig ) , and look on the soldered side , just behind the small black boxes , you'll see a spot , which has become unsoldered . You can re-solder this spot , and the compressor will run . If you do not see the spot , then the module is bad , and the control board will have to be replaced .
Sep 27, 2009 | GE Refrigerators
Craftsman Garage Opener Clicks only and LED blinking 5 times
first off, hitting extra button on remote would not do anything. Is door up or down/ where is trolley that attaches to chain, by door or motor. Is is jamned against a bolt. Try a paper clip and jump from white to read terminal. Does it work. Does light bulb blink 10 times. I ignore the diagnostic lights and go by symptons. Give more info.
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Magnovox TV
I've taken the TV to a Magnavox repair shop.
Apr 29, 2008 | Televison & Video
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
