Question about Dryers
Fridiaire dryer not turning on (another ??)
I have a 2 yr old Fridiaire Dryer, model # Fridiaire FERB7800DSO (which doesn't come up on any search engine by the way??).
I cleaned out the lint trap the other day in the middle of a load (force of habit) and the dryer has not turned on since then. I have removed the front lint trap and completely cleaned it out. Still won't turn on. When we turn the start knob it's just a quiet noise like there is something not connecting electrically. I have removed the back wiring panel just to make sure everything is still connected and has good contact with it's counter part.
Any other ideas?
your drive belt is broke. remove the front panel and then the top panel and you will see there is no belt around the drum.
well, I couldn't figure out the removing of the front & top panels, but I located a small opening at the bottom of the back panel next to the vent exhaust. I looked all around and saw a small/thin belt going around the drum. It was in place and very tight (leading me to believe that it's not the cause?) any other ideas? THANKS!!
Yes, I had the same issue. If I slam the door shut very hard then it would work. So I found the issue is the door safety switch not turning on when the door is closed. Simple fix is to put some masking or duct tape on the door so that it would push the switch when the door shuts. There is an indentation in the door in the top left corner where the door contacts the switch. This causes the door to not turn the safety switch on when closed. Simply fill in the indentation with a little tape and problem solved.
Posted on Mar 02, 2010
I have a 45 yr old Kenmore electric dryer Model 110 6608900, Serial 04158 M618. The start button does not engage; drum does not turn. What should I check and how? Is there an online manual...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 04, 2011 | Dryers
Our Frigidaire Dryer Model FERB7800DSO turns but doesn't heat. I checked the breaker and turned it off and back on with no fix. I see where some say it could be a clogged vent, bad thermostat, or...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 05, 2011 | Dryers
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
Young dryer quits in mid cycle.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 05, 2010 | Estate EED4300TQ Electric Dryer
The dryer does not heat.
If the dryer runs but does not heat, then there are many reasons why this may happen.
Remove the vent line from the rear of the dryer and see if it gets hot. if so you need to unclog the vent line.
If it does not then you have a bad thermostat .
Apr 03, 2009 | Dryers
Dryer won't start
check door switch..onthejob
Jan 27, 2009 | Crosley CDE6000 Electric Dryer
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
Jul 05, 2008 | Dryers
Kenmore dryer king size capacity 90 series
Sorry to say, but the motor needs to be replaced. motor cost around $150... 9yrs old=not worth fixing...
Jan 03, 2008 | Kenmore 63942 Dryer
Dryers Logo
110 people viewed this question
Top Dryers Experts
