Question about Epson Stylus Photo R300 InkJet Printer
EPSON 300 PRINTER
I AM NOW USING MICROSOFT VISTA WITH MY EPSON 300 PRINTER. I CAN NO LONGER SEE THE INK LEVELS. CAN YOU PLESE PROVIDE A SOLUTION? THANKS LYNN
  • Epson Master
  • 691 Answers
Download the status monitor from the Epson web site if it is available for Vista. If you have 64bit Vista chances are it is not available.
Posted on Jul 06, 2008
Why am not able to see ink level with my hp deskjet 5652 with vista operating system!
because the driver was not updated for Vista Non of the Epson ink levels show in Vista either so its not just your HP/appear to have no plan to update this feature for this model
Please rate the help++++Thanks for using FIXYA
Oct 09, 2009 | HP DeskJet 5652 InkJet Printer
Epson DX4850 problem getting ink levels to highlight using Vista
Checking the level of ink in an Epson printer can be done without having to remove the ink cartridges. This method works on black and white as well as color inkjet printers. Checking the level of ink can help you plan ahead when buying new cartridges
Instructions:
  • Install the Epson StatusMonitor software. This program comes on the CD included with the printer. It can also be downloaded from the Epson Web site. or from http://download.cnet.com/Epson-Status-Monitor-2/3000-2116_4-10024738.html
  • Open the Epson StatusMonitor program in any application (such as word processing, spreadsheets or Web browsers) that allows you to print. Click on the "File" menu tab in the control bar of the application
  • Select print or page setup from the "File" menu. A dialog box will open. In that box, click on the "StatusMonitor" icon, which will open the "Epson StatusMonitor" dialog box. Also, you can click on the "Utility" icon and then the "Epson StatusMonitor" button from the "Utility" dialog box.
  • Click on the "Update" button to update the display (if you do not think these levels are accurate) when the "Epson StatusMonitor" dialog box displays the relative ink levels for each cartridge in the printer.
  • Go back to the "Print" dialog box to change the way that the StatusMonitor utility monitors your printer and ink levels. Click on the "Utility" button again.
  • Click on the "Configuration" button in the "Utility" dialog box. The open "Configuration" dialog box will let you adjust settings such as ink level warnings and ink level monitoring before each printing.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Sep 16, 2009 | HP PSC 2210 All-In-One InkJet Printer
I need to check my ink levels, the red light is constant
go to the 'printers and faxes' folder, right click on your epson printer and choose properties, then turn to the maintenance tab and click the 'status monitor' button...
May 25, 2009 | Epson Stylus Photo R220 InkJet Printer
How to get Epson R300 stylus monitor to work in Vista
I have the same problem with my stylus C88. Epson never did provide Vista drivers so I have never found a way to get the Epson software to work with Vista. The print driver does work so you will be able to print but you'll have to clean the nozzle manually by pushing the button on the printer rather than using the Epson Monitor. Sorry.
Jan 25, 2009 | Epson Stylus Photo R300 InkJet Printer
Can't see ink levels
Re0install the driver on your pc in the control panel. when it lists all the printers, chosse the one named (M) driver. This installs a different driver, which includes a button to Get ink levels...
Oct 28, 2008 | Epson Stylus CX4800 All-In-One InkJet...
RX500 and vista
Windows Vista printer and scanner drivers are available for your product. The printer software is available by using the Automatic Software Update service built into Windows Vista. The scanner software is available for download through Epson’s website.
PRINTER DRIVER DOWNLOAD
Please follow these steps to set up your Epson product and automatically download the Windows Vista printer driver for it from Microsoft:
1. Connect the USB cable to your computer and then to your Epson product.
2. When the FOUND NEW HARDWARE window appears, select Locate and Install Driver Software (Recommended).
3. Your Epson product drivers will install automatically. You may need to select this option more than once during installation.
4. Close any open windows on your screen.
5. Try printing.
*NOTE:
-Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The LCD will display which cartridge is either low or out of ink.
-If the ink levels do not appear, click GET INK LEVELS to refresh the driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
SCANNER DRIVER DOWNLOAD AND INSTALLATION
1. Go to the Epson Support website (www.epson.com/support).
Jul 11, 2008 | Epson RX595 Photo All-In-One Printer
Epson Stylus Photo R200 and R320 Status monitor in Vista
For the Epson R200 here's how I got it to work with Vista Business 32bit ...
#1 Disable AV software
#2 Open the CD for the printer software
#3 Find the launcher, right-click it and select Properties, then select the Compatibility tab
#4 Choose XP SP2 compatibility mode and Run As Administrator, then click OK.
#5 Double-click the launcher to start the program, select Custom then then choose only the Driver and Status Monitor applications.
Worked for me, hopefully will do too for you. :o)
Jul 05, 2008 | Epson Stylus Photo R220 InkJet Printer
Compatability epson r300/vista
Did you go to Epson.com and check for upgraded drivers for Vista?
Apr 15, 2008 | Epson Stylus Photo R300 InkJet Printer
Vista cannot regocnise my rx600
5. Try printing.
*NOTE:
2. Select your model, then select Drivers and Downloads.
3. Select and download the TWAIN Driver and EPSON Scan Utility for Windows Vista. Save the file to your desktop and make a note of the file name in order to easily retrieve it.
4. Double-click the downloaded file and follow the on-screen instructions to complete the installation.
If a message appears indicating “The scanner has not passed Windows Logo testing”, click Continue Anyway. Then click Finish.
5. Re-start your computer before testing the scanner software.
Jan 05, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Photo R300 InkJet Printer Logo
104 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
