Question about Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum
Replace on/off power switch for BUC11700UC vacuum cleaner
I am not able to remove the covers which enclose the switch. Can anyone help me
  • Anonymous Oct 05, 2008
    The power switch on my BUC11700uc has gone bad. For some time it would work if I held it in on position but now it is totally gone. Where do I find the spare switch and where do I find instructions to install it? I am a handy man and if I know how to open the switch housing, it should not be difficult to replace it.
    Problem Solver:
  • 14 Answers
Bryanv
Thank you for and excellent solution. I have several suggestions:
1) After removing the 11 screws as directed, I was unable to remove the handle. However, I was able to sneak in and remove the one screw that holds the top front thingy. I should warn you that it is easy to break the tab at the switch end of the front thingy. It was zip wired to the handle. (How do I know, I'll let you guess:-)
2) I would recommend re-soldering the wires to the new switch. They are already tinned and take up much less room than push on connectors.
3) Finally, be sure to use insulating shrink tubing. Put it on before soldering. Duh!
Posted on Apr 11, 2009
I had the same problem. I ordered a new switch from a local appliance place part#417915 (also try 54542), but it can be found on-line for ~$2+shipping. There are 11 screws to remove. Remove all nine screws that hold on the back of the handle (be sure and get the two under the attachment holder). Remove the two screw from the front that hold the top dirt canister retaining bracket. Once you have the back of the handle off, you can remove the single screw at the top of the handle that holds on the top front where the switch is. The front will then 'snap' off.
The wires are soldered to the switch, and there is absolutely no slack in the wires, so I don't recommend that you cut them. Be very careful with the new switch, since the tabs on back can break off very easily if bent too much (speaking from experience). You might also want to order, and keep and extra switch, around for the next time you need to replace it (it will wear out again).
Instead of soldering the wires to the switch you might want to try using some push on female spade connectors (small), but be sure they are insulated. This will make the next replacement much easier.
Posted on Feb 02, 2009
Model VC248. How do I remove cover to replace power switch?
[PDF]User Manual
www.cirrusvacuum.com/.../CR69A,79,99%20UPRIGHT%20MANUAL....
any openings or moving parts of the vacuum cleaner. I ... Cover 0 o l L I Hose cuff. Furniture lljm- 5 j. Guard _ u _"°-*_-'e"'"__ .' . ..... Cirrus wilt, at its option, repair or replace a defective vacuum or vacuum cleaner part that is covered by this ...
Sep 19, 2015 | Cirrus Vacuums
Can anyone please help, my Miele vacuum cleaner will not switch on anymore.
www.mieleusa.com/Service
Most likely problem one of the wires leading to the switch. Ohm them out with a OHM function of a multimeter, while unpluuged , of course. .
Sep 14, 2014 | Miele Vacuums
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    Vacuum cleaner shuts off after short use. What's the reason. Motor seems very hot.
    Almost all vacuum cleaners have a thermal cut-out, which operates when the machine gets too hot. It resets automatically when it cools down. Overheating is almost always caused by a blockage. Either the filters need cleaning or changing, or there's an obstruction somewhere in the pipe-work. Make sure all the pipes are clear so there's good air flow and you should be back in business. If the problem persists there may be trouble with the motor itself, in which case you'll need professional help (or a new machine). Good luck!
    Jul 17, 2009 | Bosch BUC11700UC Cyclone Jet Bagless...
    My vacuum died. It won't turn on. It is not the outlet. Is it a blown fuse? How do I replace the fuse? Where does it go? This vacuum is a little over 2 years old. My older Hoover WindTunnel STILL works and...
    It's probably the power switch. My switch was dicey for a couple years, finally gave out. Easy to replace.
    Remove the two screws just above the WARNING on the rear of the upper handle assembly, then slide the whole assembly to the rear of the vacuum.
    Remove the dust bag cover. You will see two holes just above the upper corners of the dust bag. Remove the screws from these recessed screw holes.
    Open the furniture cleaner cover and remove the cleaner attachment. Remove the single screw that was hidden behind the attachment. Then remove the attachment housing by pulling it towards the front of the vacuum.
    Inside you will see the rear of the power switch. Pull off the power wires (don't worry, easy on/off male/female connectors, no soldering).
    The switch is held in by tension bars at the upper and lower rear of the switch. Firmly press down on one of both of the upper/lower tension bars, and push the switch through the housing from the rear of the switch.
    Replacement part number is 28161067, about $2.50. Shop will charge about $85 to repair it themselves.
    Jul 09, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
    Bad on/off switch hoover U6476
    Feb 01, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
    Bosch Vacuum upright
    its a problem with the power switch you can wire nut the wires together but I have been looking for parts myself.
    May 20, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
    Bosch BUC11700UC Cyclone Jet Upright Bagless Vaccum
    Apr 08, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
    Panasonic Vacuum MC-E450UK
    Panasonic MC-E 450UK upright vacuum cleaner.
    Just had this problem myself...........easy to get at it when you know how.
    Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
    Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
    Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
    Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
    Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
    There you go! Told you it was easy!
    Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
    You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
    Happy fixing!!
    Jack.
    Apr 07, 2008 | Vacuums
    Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum Logo
    498 people viewed this question
    Top Bosch Vacuums Experts
    Billy Detlefsen
    ray gallant
    JoeVacs
    Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
