RE: ASUS eee When booting the eee shows the Windows screen as normal but when Windos starts, the screen is sideways. Can you tell me why?
  • ael1 Jul 06, 2008
    The video card was set completely different and would not allow changes so I did a restore to fix it. Thanks for the assistance.
    Ron Phillips, Halifax N.S.
  • 983 Answers
I think the H size & V size in the monitor is not seted correctly ...
just do one thing go to safe mode by pressing F8 at the start up ...
there in safe mode you set the H size & V size by using the monitor buttons which will be present in the menu ,the monitor buttons will be there at front panel ....
just adjust the screen size now correctly after that just reboot the system you will be able to see the screen seted correctly
Posted on Jul 05, 2008
  • 3 more comments
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jul 05, 2008
    if the screen is rotated then press
    ctrl + alt + up arrow or down or side arrows ...
    your screen will be placed correctly
    if the screen is rotated then those are the hot keys you must use ...
    any further help you can reply me
    this is happened because sometime you might have pressed by mistake ctrl + alt + some arrow key .....
    the hot key will be enabled defaultly so your screen got rotated
    if the screen has been rotated right side or left side or 180 degree then press
    ctrl key + alt key + up arrow ...
    that will place the screen in the normal position ...
    Guru:
  • 1,342 Answers
You should be able to go into your display settings and rotate your screen. Right click on your desktop and select properties to access your display settings.
  • Georgia B
    Georgia B Jul 05, 2008
    If you have a separate program installed for your graphics card you may have to use that.
    President:
  • 1,314 Answers
Most likely because you have a graphics driver and it is set to rotate the screen. Go into your graphics properties, click on advanced, and find the place where it says rotate screen.
OR
You can just lay your monitor on it's side lol :c)
    Brigadier General:
  • 3,614 Answers
Try to adjust the setting on your monitor, the video card must be set on the resolution of your monitor...
let me know...
Unable to enter Asus 6850 BIOS
I would start by resetting your bios settings to default; turn off your system, remove the side cover and gently pry out the board battery (round "button battery" such as cr2032). Leave it out for about one minute, and reinstall. Then see if you get a post screen.
Dec 29, 2013 | ASUS Computers & Internet
I want my asus eee top to be set back to factory settings
first you should back up all the documents and important files on some external drive, then insert the recovery disk select the first boot option from the bios to cd/dvd, then follow the instrcutions
Feb 05, 2013 | ASUS Eee Top ET1602C (ETP1602CBKX0163) 156...
Winfast boot sequence problem
Boot sequence problem? You set the boot sequence permanently in the Bios or System Setup. Normally when you boot the system the screen will tell you what key to hit to get into the Bios or Systems Setup.
You can set the boot sequence temporarily (just for the current boot cycle) by watching the screen when you boot and it will tell you which key to hit to change the boot sequence or boot order.
May 07, 2012 | ASUS Computers & Internet
Blank screen on my Eee Top 1602
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Dec 16, 2011 | ASUS Eee Top ET1602 PC Desktop
Asus cs5111 small form factor "missing operating system"
hard drive problem either damadge or virus do a drive check at setup when you start computer (whats result) then if you boot it once when you get to main screen windows do scandisk
May 26, 2010 | ASUS Essentio Desktop with Intel Pentium...
Cyclic boot and reboot after installing SP2
If you have the Windows XP recovery disk you should boot into the disk and do a repair install of the Windows OS. You can also press 'F8' before or right after the Windows XP splash screen comes up and tell it to either boot into Safe Mode or "Boot with last configuration that worked". If you boot into safe mode, go to control panel and programs and uninstall the sp2 installation. Please comment back if you need further assistance. I will be providing a How-To on how to recover a system using system CDs today.
Good Luck,
NOLA Tech
Jan 27, 2010 | Computers & Internet
Recently installed windows xp3 service pack have to rebooth desktop with asus p4s800-mx se motherboard on emachine 21o desktop, how can do normal boot up can i remove the service pack
when start your computer press the f8 button its show the safemode click the safemode and open the windows in a safemode when your computer start then open start>all program files>accessory>system tools> system restore> open it and choose the date when your windows is working with sp2 after that click next and finish it your pc take a reboot then its restore your sp3 will be remove from your pc
thanks
rate me if solve
Oct 01, 2008 | ASUS Computers & Internet
Asus eee pc windows blue screen on start up nothing
we call that Blue screen of dead(bsod)...and sometimes got message Unmountable bootvolume....need to run chkdisk and after that just restart and everything back to normal..
when U last format or clean install the asus eee pc?....
Aug 09, 2008 | Computers & Internet
My computer starts but before booting it shuts down.
You may have lost part of your windows program. If you have a system restore disk, you can run a system restore and probably fix your problem.
Some of your windows files have gotten deleted. When windows gets to this point all windows knows to do is restart. A virus can cause this problem.
Stargazer
Mar 16, 2008 | Gateway 310S (2900621) PC Desktop
Computers & Internet Logo
81 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
