Question about JVC Office Equipment & Supplies
I have changed the lamp but can't reset the lamp time on my DLA-HD1 projector. I have followed the instructions in the manual but it won't reset.
  • theleightons Dec 28, 2010
    Unfortunately your solution didn't work, also my projector was set up by an expert so i don;t want to lose all the current settings. Do you have any other suggestions or know anyone else that might be able to suggest something?
  • theleightons Dec 29, 2010
    I thought that might be the case, thanks for your help anyway.
  • 629 Answers
Try turning off the projector, disconnect the power cord and remove the lamp again. then press the power button for about 10 seconds to fully drain power. afterwards, connect/insert the lamp again making sure it is securely connected with the cover, power on the device and attempt to reset the lamp time again. let us know how it goes.
Posted on Dec 26, 2010
  • 1 more comment
  • Rodie Dec 28, 2010
    if you are worried on losing anything, you may want to consult the same expert who set it up so he can check it further for you. Based on the details, it may be needed that the projector settings/configuration has to be reset to factory defaults if the lamp time reset does not still work.
  • Rodie Dec 31, 2010
    not a problem and hope you'll get this sorted out
  • cc362 Apr 06, 2014
    Make sure you are punching the right buttons on the circle of buttons. There are inside buttons and outside buttons. It took me several tries until I realized I was pushing the outside ones instead of the inside ones. Once I carefully looked at the button setup, I had no problems.
Warning and standby indicator of JVC D-ILA Projector model DLA-X70RBE flashing simultaneously.
Johan, Below are links to your model where you can access,manual,instructions and get support.
Press the helpful button and follow me on fixya for more tips and info.
4K shift ILA Projector DLA X70R Introduction
Replacing lamp on JVC Series Projectors
JVC DLA X3 Warning light issues
Feb 11, 2016 | JVC Televison & Video
Failure to change Filter Time
unplug projector for about an hour, and then remove bulb, and filter, inspect areas for damage, also inspect it to make sure your inserting it correctly. put filter and bulb back in, put covers back on, then plug it back in. reset the timer. if you still have problems let me know.
May 06, 2008 | Hitachi Performa CP-RS55 Multimedia...
How I can reset the lamps time?of this model Sony PVLPX41
Make sure that the projector is in standby mode and perform the following:
Press the following keys on the control panel in the following sequence for less than 5 seconds each: RESET, , ENTER
In english: RESET
LEFT ARROW
RIGHT ARROW
ENTER
Please note that this sequence is documented on page 43 of the user manual under changing the lamp.
Dan
May 23, 2011 | Sony VPL-PX41 Multimedia Projector
When i put my DLA-D15 on the standby ligth goes on when i put operate on it come and goes off after 10 seconds and the fans don't operate.could you tell me whats wrong?and the lamp has only 200 hours
hi,
First of check the lamp of your projector. possibility of lamp burning. Remove the lamp from the projector and check whether it burned or not. If not, insert the lamp back and close the lamp cover properly. If the lamp cover is not properly closed this problem can occur, because there is switch to sense whether the lamp cover is closed or not.
If these will not help then you have to open your projector. Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
ok
Mar 08, 2011 | JVC DLA-G15U Multimedia Projector
Excuse me I recently changed the bulb on my JVC HDMI DLA-1 Projector and it still says I need to change the bulb how do I solve this issue?
Agreed with Fathi, Press and hold down the video, settings and quick alighn + > at the same time for six seconds. While the stand by and operate indicators are on, press video, settings and computer buttons at the same time.
Apr 11, 2010 | JVC DLA-G15 Multimedia Projector
Reset timer on jvc dla g150c projectorlamp
1 Turn on the MAIN POWER switch to go
into stand-by mode.
In stand-by mode, the STAND BY indicator on the
projector lights up.
2 Press the following buttons on the
projector, sequentially.
1 Momentary press the PC button.
2 Momentary press the ENTER button.
3 Momentary press the EXIT button.
4 Press and hold the HIDE button for two seconds
or more.
* During this sequence, the STAND BY and OPERATE
indicators alternately blink about every approx. 3 seconds.
After completion of the sequence, the STAND BY indicator
alone stays on.
* Buttons must be pressed within 2 seconds of the previous
button.
* When you make a mistake in button operations, return to
the beginning of the sequence.
* To check the lamp time on the menu, press the MENU button
and select “Information” with the cursor button 5 or ∞.
The lamp use time is indicated in the item “Lamp time”.
Sep 30, 2009 | JVC DLA-G150CL Multimedia Projector
Sharp projector XV Z90U
I also had this issue - followed the On, Input, Undo, Left, Enter, Right, On button sequence several times. Then I decided to push them in that sequence very quickly and it worked. The lamp LED on the front changed to green and the projector started up. So the button sequence they provide in the manual works, you just have to push them in rapid succession. Hope that helps.
Oct 31, 2007 | Sharp Projector lamp Projector Lamp
Dla-g15 comes on but do not start
does the cooling fan come on at all during the instant that it turns on for? If not then the problem is almost certainly overheating, depending on exactly how long it takes to turn off - is it so "instantly" that it is before you get your finger off the button, or is it a couple of seconds or so. If the fan does come on then so long as you are fairly sure all filters etc are clean the most likely problem is the lamp is not installed correctly or there could be a fault in the temperature sensor. check the lamp installation instructions and make sure you have followed them exactly. post back and we can look for more info if you need it :)
Jun 26, 2007 | JVC DLA-G15 Multimedia Projector
609 people viewed this question
Top JVC Office Equipment & Supplies Experts
MusicMania
Level 1 Expert
Piyal Perera
Piyal Perera
jasbo
jasbo
Are you a JVC Office Equipment and Supply Expert? Answer questions, earn points and help others
