WELCOME TO OUR COMPUTER HELP PROJECT This project is presented by My Memory
Summary: Diy computer help: Upgrade and install a video card.
<< Back to projects
How to Upgrade and Install a Video CardThis guide assumes that you have decided your current video card isnot performing well with today's applications and that you have decidedto remedy this situation by purchasing a newer, more up-to-date videocard
Preparing for Installation
Before you start installing a video card, make sure you have the following items with you:
Diagram of a typical video card
The illustration below showsyou what a typical video card looks like. Refer to this diagram if anyof the terminology used in the instructions confuses you.
Removing the driver for the current video card
Windows refers to your video card as a "Display Adapter." To make theinstallation process easier, you must tell Windows to use its genericdisplay adapter driver, which has settings that will work with everyvideo card. Otherwise, your current video card settings might interferewith your new video card.
Note :If you are running Windows NT, 2000, or XP, make sure you arelogged in as an Administrator. Otherwise you will be unable to completethese steps.
To read more go to
http://www.guardianit.co.uk/modules.php?name=Content&pa=showpage&pid=6
DIY Laptop/ Notebook Computer - Do It Yourself Notebook, Picture TutorialBy Dr. Michael Copyright © Directron.com 2005
Most
of us have built our own desktop and even server computers. Now several
companies offer barebone laptops for consumers/individuals to build
their own laptops. All you need to purchase and put together are:
Then, you'll load the operating system software and add any laptop accessory you may want.
About
two weeks ago, I was fortunate to be invited to Asus' US headquarter in
Fremont, CA to their vendor program, which includes a hands-on training
on assembling a DIY laptop. Although we have been selling the Asus
barebone for a while, this is the first time I have experienced the
process of building a laptop myself.
The process is actually
very simple. With a hard drive pre-loaded with the OS, it took only
about 10-15 minutes to finish the entire assembling process. In
comparison, building a laptop is much easier than building a desktop PC
from scratch, but much like building a desktop from a barebone system
such as Shuttle or Asus cubes. The process is made allot easier because
the motherboard and almost all the cables are pre-connected already.
The engineers already worked out the details for us - the end-user - to
install the memory, CPU, hard drive, and a built-in wire-less network
adapter in this case.
If you can use a relatively small screw driver, you can do it!
Here are some pictures from the entire process.A
picture showing the back of the laptop with CPU chamber (open), hard
drive chamber (top left corner, closed), memory/WiFi chamber (middle,
closed), and battery chamber (lower, open). The
most tricky part is to remove the heat sink and pipe before mounting
the CPU. You have little space to work with. Obviously, you try not to
break anything. Now
working on the memory chamber. The cover is removed by removing one
screw. (Warning: the screws are small. Keep them in a safe space). Now it's time to add the internal WiFi card. This card adds a wireless network adapter to the laptop!
There
are two wires that need to be connected to the WiFi card (one black and
one white). The connectors are a clip-on-bottom type. They are a little
difficult to work with. Since they the WiFi card is not supported well,
it's difficult to push the click-on bottoms onto the card without
putting too much pressure on the card itself. What I did was to place a
screw driver head underneath the card to support it while pushing the
clips. Slide
the drive bracket into the HD chamber with the IDE pins going into the
connector. Push it to make sure the connection is tight. And then ready
for putting the cover back on. Now I was ready to power up this baby! It booted normally the first time! Everyone is happy to see that.
Since
the hard drive was preloaded with OS already, we saved the time for
loading the OS. The entire assembling process took about 10-15 minutes.
It may take longer for people who have never put a computer together or
shorter for those who are really good at building PCs.
I
would like to thank Asus for sponsoring such training and the entire
trip, which included a one-day visit to Napa wine country.
(Last updated 04-22-05) Go to Top
(c) Directron.com, All Rights Reserved
If
you find this article useful, please create a link to it from your
website or tell a friend about it. If you have any comments or
suggestions about this article, please email [email protected]
click the; GO TO TOP you can see picture step by step how:
If my solution help you to understand your problem please rate me as fixya.
Are you talking about your aspire laptop? If that's the case, the video is built into the motherboard and the only way to replace it is to replace the motherboard. A motherboard, if you could find one, would run around $100 plus it's not an easy thing to replace on a laptop. It could take 2 hours for an experienced tech with the service manual to do it. It would be far cheaper for you to replace the computer plus you'd get a warranty.
Most of the video cards are really simple to install. what kind of card are you getting?
I could make a video myself but theres already a few available
watch this
Tiger How-To: Install a Graphics Card in Your PC
http://www.youtube.com/watch?v=5ILrq7lMe...
Oh you are the acer guy? the video card may be build into the motherboard and in that case you can't replace it, you would have to replace the whole motherboard.
By the way, we can't share payments, only the solution which is accepted gets 4-6 dollars out from it. Also if no solution is accepted the payment goes to the first guy who answered.
The motherboard costs around 400 to 600 usd, its better to buy a new laptop.
your acer was the 5100 series?
http://www.acerparts.com/index.php?cPath...
3 369 Swedish kronor = 564.011028 U.S. dollars
