Question about Dell Latitude D800 Notebook
Dell D800 Problems!!
Hi There
I have a D800 and I am having problems:
basically It wont stay on if it's not attached to a plug,
I can't switch it off because I know I wont be able to start it up again,
It seems that if I don't use it for a bit I can switch it on again,
and previuos to that it used to switch on by it self in the middle of the night,
Do I have to call a GOST BUSTER or a simple technical support guy!!!
  • karans Sep 08, 2008
    Upgraded my DELL D800 to 2G RAM and now it only runs on batteries - shuts down as soon as I plug the AC power - runs ok when it runs on 1G.
  • Anonymous Jan 23, 2009
    My buddy's Dell would only run off of battery power not AC. When the battery lost it's charge (after about 2 hours of use) he would shut his machine down, plug it in, and wait for the battery to charge back up. Talk about an inconvenience. After being stuck on the phone with Dell Tech support, they told him the motherboard was most likely fried and that he would have to pay an absorbent amount of money to have it fixed.
    Well, it ended up being a bad piece of memory, and he would have never had known if it weren't for the person ahead of me with the same problem. I would have never guessed that memory would cause the problem, but it's definitely worth a try. If I could give a FixYa rating to the person ahead of me, I would!
  • 2,028 Answers
Could be a short in the battery, Dell batteries are notorious for this. Try running it without the battery for a while. If the problem goes away, then it'e tome for a new battery.
Posted on Jul 07, 2008
Hi! my dell d800 wont turn on. I have take then battery out and such and then put it back in but it still wont work. I have put the charger into the computer and the computer says its not charging the...
the battery is damaged..replace the battery with a new one or you will have to run your laptop straight from a eletric power source with the battery removed.
May 02, 2010 | Dell Latitude D800 Notebook
Dell d800 unresponsive
should your machine become unresponsive to on-off switch it is usually because it comes un-plugged from the board, to fix pry bezel up and re-connect plug.
on Sep 22, 2011 | Dell Latitude D800 Notebook
Cursor tend to go spastic when I touch the keyboard on my Dell
I had this problem and it was solved by turning off the touchpad in the bios,
Pressing the f10 ? or f2 ? during startup will get you into the bios
are you sure the mouse is ok ?
Dec 10, 2009 | Dell Latitude D800 Notebook
Dell Latitude D800 Wont Power Up
Check the status of the battery directly from the battery. Turn the laptop over and on the batter is an battery indicator button and lights to tell you if it's charged. If it is charged then you have an problem internally. Wiggle the tip of the power cord at the laptop connection to see if it is loose, if it is then you have an loose connection on the motherboard which can be fixed by an experienced tech that can solder or the motherboard will need to be replaced.
Nov 12, 2009 | Dell Latitude D800 Notebook
WXGA Display for Dell Latitude D800 Problem. When
replace either your cold cathode screen lamp or, your inverter board in your display
Aug 28, 2009 | Dell Latitude D800 Notebook
Dell D800 Won't power up at all?
Bad news, this most likely indicates a problem in the charging circuit on the mainboard. To be sure, remove the battery and try again, if the same thing happens, then the problem is on the mainboard, if not, replace the battery. I have encountered this problem on an older Dell laptop before, removing the battery did not help and replacing the charger did not help. If the problem is on the mainboard, replacement is rarely practical. The cost of the board and the labor to replace it usually exceeds the cost of replacing the laptop.
Hopefully someone else has a better solution.
May 24, 2009 | Dell Latitude D800 Notebook
D800 will not even boot
Okay, I had that problem with my HP less than a minute ago.
Maybe it is the same problem. See if the battery light comes on. Press the power button again and again if it doesn't start, for some time. It may show the boot screen and hang. Now, the battery must be charged. Shut it down directly and switch the AC off.
Now, switch it on and see if the battery light comes on. If it does, it is the same problem as mine. Now, turn the PC over and remove the battery carefully. There may be switches for that.
Now, plug in the AC and start it without the battery in. If it does, you're done. Now, plug in the battery again.
Nov 28, 2008 | Dell Latitude D600 Notebook
Dell Latitude D800 Processor slows down
This is the SpeedStep technology feature of your processor. It will speed back up to 1.7 GHz when it is needed. Slowing down the processor saves battery life.
Jan 01, 2008 | Dell Latitude D800 Notebook
Latitude D800 wont boot
ok now it sounds to me the power pack on the back has shat its self so ufourtanetly u need a new one if u still have a valid warrenty ring dell or go to their web site at and they will happiley help u there number is also their but if u dont have warrenty go to their website and see how much it costs for a new battery but see a friend who has a dell laptop and plug in the power cord it might be your power cord not your com or battery so give it a wirl and if u have any problems email me at
Dec 31, 2007 | Dell Latitude D800 Notebook
Not powering up.
Could be either but it's pretty common to have power socket or power pin problems. The pins/Sockets are poorly designed and poorly manufactured. There is a HUGE industry in just fixing the pin/socket problems on laptops. I've fixed one each on my Sony Z505 and my wifes Fujitsu. The problem is caused by the daily tugging and pulling on the cord. It puts strain on the poorly designed socket.
Once you get it fixed you might try gettinga Cable Retention Device like the one on this video. . . I did and so far no more pin problems.
Oct 21, 2007 | Dell Latitude D800 Notebook
Dell Latitude D800 Notebook Logo
100 people viewed this question
Alun Cox
