SOURCE: hooking up portable dvd player to sharp aquos tv
Audio and video out from the DVD unit go to the A/V In of the Sharp....Accordianman
SOURCE: HDTV Sharp- Input select to watch Cable tv
On the sharp remote you will find an input button. You depress the input button and a menu will appear and highlight the input you are presently on. Hit the input button again to select the next input. If you wait to long to depress the input button it will not work and you have to begin again. This unit will only hightlight inputs have a component hooked to that input.
SOURCE: Yellow Video Cable Won't Work
Hi there!
First of all try another PS2 cable. Make sure you select the correct input. May be a loose connection inside on the actual video input socket. May also be a faulty video circuit caused by static discharge from an external source (Lightning,Power Surges). The latter will have to be repaired by a repair technician and can be rather costly, so shop around first. Good Luck,JUS004
SOURCE: DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Connect a set of RCA audio and video cables to the color-coded outputs
on the back of your Samsung VHS/DVD player. The colors of these cables are
yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to
the color-corresponding inputs on your television. When plugging in these
cables, look for a label for the input, such as "Video 1" and
"Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step
3. If you did not take note, you can also tune through your television's input
channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the
"Play" button to verify that the unit is functioning properly.
Component Video
Plug the power cable of the Samsung VHS/DVD player into an available
power outlet near the television.
Connect a set of component video cables to the color-coded outputs on
the back of your Samsung VHS/DVD player. These cables will look similar to
composite audio and video cables, but they are instead color-coded as red, blue
and green.
Plug the other end of the component video cables into the
color-corresponding inputs on your television. Take note of what input number
you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your
VHS/DVD player, then connect the other ends to your television. These cables
are color-coded as red and white and must be plugged into the same input number
as the component video cables.
Tune your television to the component video input channel where you
connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play"
