EnGenius ESR-1221 EXT Router Logo
A
Anonymous Posted on Dec 26, 2010
My router was install by a satelite installer and i do not know the network password. how may i reset the password if i don,t know it.
Jeffrey Groves
Level 3:
  • Master 573 Answers
  • Posted on Dec 26, 2010
Jeffrey Groves
Master
Level 3:
Answers
573
Questions
Helped
140442
Points
1832
You will have to perform a factory reset on the router.
Looking at page 6 of the user manual for this device, I see there is a RESET button on the back.
Use the tip of a ballpoint pen to press and hold the RESET button on the back for about 15 to 20 seconds. This will set your router back to factory defaults.
After you've done this, start the procedure on page 10 of the user manual to configure the router using your web browser.
Be sure to set-up WPA/WPA2 security on your router as described starting at page 31. If at all possible, do not use WEP security. WEP security has been cracked and can easily be cracked.
I LOST INSTALLATION CD FOR MY D-LINK DIR-600
->Download the manual from the router website and find the username and password,if you don't no the default password.Then reset the router to go for default login.
->Most d-Link routers have the IP address of 192.168.0.1 login using username and password.
->After login select "Manual Wireless Network Setup" from setup tab.
->Your basic wireless network settings are in this screen. First, give your wireless router a name that you can recognize it by. Secondly, select a type of Security Mode. WEP-Personal should be efficient for most people's usages. After that is selected a new window at the bottom appears.Type your password in the Pre-Shared Key, scroll to the top and hit save, and that's all there is to it.
If you need any kind of technical assistance on router, you can contact support cell at http://www.vtechsquad.com/
How do i reset the password to my 2wire router an connect a wireless laptop
Is your 2Wire Router by AT&T, if so the password is on the side or bottom of the router. Look for Network Key or Network Password on the router.
Once you have that, you simply go to your laptop, and try connecting to your wireless router. It will be the one with the strongest signal if you don't know your SSID. Once you click connect, it will ask you for the password/passphrase or key, type in what you found on the router.
There is really no need to reset the password unless you have some other reason. But there are 2 ways to reset the router's password, you will need to have a computer that is connected to the router with a network cable (most times this is a desktop already connected). Then you will need to know the router's IP Address to type into a internet browser. It will be a set of numbers such as 192.168.1.1 that you would type into the address bar where you normally type www to get to a web page. Once you have the right ip address you will need the router's login id and password. Most times this is set to the default unless whoever set it up changed it. Once you are in the router then you go to the wireless and wireless security area to change the password. If you don't know the ip address or the userid and password for the router, then you can google it on the internet.
If your internet provider is AT&T you might be better off calling them to reset your router's password. They can walk you through it.
2answers
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Im trying to install Linksys2000 to my computer , but keep being asked for Router password. What is the password. This router came with no software even tho the packaging says it does . Its damned...
Normally userame and password of linksys Router is admin and admin respectively, if it is not changed,
if still can't access, you can reset your router by pressing and holding reset button for few seconds,
Thank you, Please don't forget to rate me.... please
Dear D-links, I have a DIR 300, I had installed
if you can connect to your router using a cat 5 cable with your macbook.
you need to reset your router if you do not know the password.
reset it by holding the reset button and power on the router while holding the button for 30 secs.
the default login/pass is admin/admin
follow the guide below here
http://www.ehow.com/how_5167471_secure-wireless-network-dlink.html
to secure your wireless network.
1helpful
2answers
Forgot password
To ilysurita, cj_mom, top_shutta…
First can I clarify what is meant by a ‘lost password’ …. The original poster here is asking about the password needed to login to the router configuration pages.
If you know the password to login to the router configuration pages, you can still get access to the network key (also known as passphrase, WPA or WEP key, PSK, pre-shared key) – which is the key Windows asks for to connect a new computer to the network. It will be found under a heading like ‘Wireless Security’ or ‘Wireless Settings’ within the router configuration pages. For this model, you can find the router configuration pages by typing www.routerlogin.net (or .com) into a web browser, or http://192.168.0.1
If you don’t know the username/password to login to your router, try using the defaults – for this model, they are admin and password.
However, if the router login username/password has been forgotten, the only way to regain access to the router configuration settings is to reset the router, as described in my posting above. I don’t know of any shortcuts to this one. :(
If you have to resort to this, you might want to wait for whoever set up the router to help with this. This is because resetting the router will remove all your settings – password, network key, ISP connection info – so you will lose your internet connection altogether until it is set up again.
On the other hand, if you’re willing to spend some time and patience, you can have a go yourself.
If you have your original setup CD this may contain a software wizard to walk you through it. If not, you might be able to download a setup wizard from the router manufacturer’s website, along with a quick installation guide (and a manual).
The Netgear site also has very clear troubleshooting and support pages which will help with setup, even if you don’t have any setup software:
http://kbserver.netgear.com/products/wgr614v9.asp
Make sure you use a wired connection. Also, print off all the information you need before you begin, as you will not be able to access the internet while you are setting up the router.
Good luck whatever you decide to do
2answers
Connecting second laptop to my Belkin Wireless G router
I don't know the model of your router this would be very helpful. Most routers have a reset button on the back of the router. This will reset your router back to factory default settings.This will reset the pasword to default usually "admin". You will need to set up your router all over again. Let me know the model and I can send you a link for installation of your router.
Ssid password
Dear Keith118,
I assume you know how to access the the router from your computer,
1. try resetting the router so that it will revert back to its factory settings.
2. this way the default user name will be admin with with a blank password.
3. the manual has an instruction how to reset the unit.
sid
Top EnGenius Computers & Internet Experts
john h
Krzysztof Tomasz
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
