Question about Motorola Mobility RAZR V3
Somehow got wet but i comes on
My cell phone somehow got water damaged and it comes on ony once in a blue moon...anyway when it does come on it sometimes a white screen appears!! when my reular screen appairs the white screen sometimes appairs and it shuts off and on i really dont want to buy a new phone pleaze help me and say thiers a way to fix it!!
    Brigadier General:
  • 7,752 Answers
It depends....but take it to a mobile service center and have them check n service the phone to see if it is worth fixing or for you to just buy a new one.
Posted on Jul 05, 2008
I got my lumia soaking wet in a storm how do I get it going again?
Er. idk. BUT i once dropped my phone in a bucket of water,
and my gf fixed it somehow.
... idk, what she did but it is POSSIBLE to fix it..
Aug 21, 2014 | Nokia Lumia 920
Nokia C5 got wet and now holds charge for a few hours only
You need to get your Phone serviced as soon as possible to avoid further damage.There must be water logged in it ,which can cause a short circuit,which may brick the phone.
Dec 08, 2011 | Nokia C5 Cell Phone
My iphone i spilt water on it and it got wet, know it wont come on, what can i do? will it work once it dries?
i recommend to put your phone in rice to absorb any moisture. it depends on how bad the phone has been damaged on if it will work.
Mar 12, 2011 | Cell Phones
My sony ericsson was soak wet and i cannot open or used it anymore
Hello Villanuev514,
Usually, once your phone soak in water, also known as water damage, the phone will not function well or worst, it will not turned on because there are some hardware components that once it got wet, it will be damage.
I would suggest that you remove the battery immediately and bring it to your local service provider to have it check because once the battery is still connected to the phone, it can create more damage to your Sony Ericsson since the electric is still running and the water is a very good conductor that can short the circuit.
The best resolution is to bring it to your local service provider since there are hardware components that might be defective. Please note certain charges applies depending on the issue of the phone.
I hope it would be helpful.
Thank you,
Feb 17, 2011 | Cell Phones
Mobile in water not working now
Remove The Phone From The Water
The first step is to remove the phone from the water as soon as possible. The less time the phone spends submerged, the greater chance it has of being saved. The plastic covers that come with cell phones do provide some protection, but it takes a mere twenty seconds or less for water to get through these barriers and start causing damage to your phone.
Once you pull the phone from the water, remove the battery immediately. Cutting power is a crucial step when attempting to save a wet cell phone. There are many circuits inside cell phones that can survive getting wet, but only if they are not attached to a power source.
If your cell phone comes with a SIM card, remove it promptly. Do not heat the card, simply pat it dry with a soft towel, and put it aside until the rest of your phone is dry and back to working order. The good news is that SIM cards recover well from water damage. If for some reason, your phone doesn't survive the accident but the SIM card does, there are plenty of places that sell unlocked cell phones. Simply place your SIM chip into the new phone and go.
Salt Water Accident
Please take note; if your phone was submerged in salt water, you must rinse it in fresh water before the drying process begins. Even after the phone is dry, crystals can form and continue to cause damage and erosion.
Let Your Phone Dry
The next step you must take to save a wet cell phone is to allow the phone to dry. A great method in providing an optimum drying environment is to set the phone on the vent found on the back of a television set or cable box. The low heat emitted will gently dry your cell phone. Another trick to help speed drying is to place the phone in a bowl of dry rice. This will help draw out the moisture. You can also try placing the phone in a plastic baggie with a few silica packs that come in purchases such as shoes and electronics. Silica, like rice, absorbs moisture.
The important part of the drying process is to place the phone uncovered, in a warm, dry place and allow the moisture to evaporate completely. Another alternative is to place the phone on an air conditioner. The cold air will not damage the phone and the air from an air conditioner is very dry allowing the water to evaporate quickly.
Drying should take approximately three days at which time you can check to make sure the phone is clean and dry. It is at this time that you can re attach the battery and check if the phone works. If it doesn't, wait a few more days and try again. If the phone still doesn't work, take it to your local dealer, they may be able to repair it. Be prepared; getting a cell phone wet will void your warranty and most cell phones are equipped with a water damage indicator so the dealer will know the phone has been H2O compromised.
Alternative Drying Methods
There is an alternative way to save a wet cell phone that includes an alcohol soak. Alcohol is hygroscopic which means that it attracts water. Soaking your phone in denatured alcohol, or a 95% alcohol solution (regular rubbing alcohol is about 75%), soaks up all the water in the phone. When the liquid is dumped out, only alcohol, which will evaporate, remains. Make sure that the alcohol you use is denatured with only methanol as the chemicals found in other types can be damaging. This kind of alcohol can be purchased at your local hardware store. The alcohol soak may work best for phones that have been damaged by salt water or other liquids such as coffee.
Battery Caution
When attempting to save a wet cell phone, make sure you do not heat the battery as it could leak or even explode. Lithium-ion batteries are especially sensitive. In addition, many cell phones have plastic parts that can melt. Above all, do not try to save a wet cell phone by placing it in a microwave. You will destroy the electronic components and possibly the microwave in the process.
The above steps will help to save a wet cell phone, but be prepared. Often the phone will survive but the battery will not and the purchase of a new one may be in order. Good Luck!
Dec 05, 2010 | Nokia 2690 Cell Phone
Phone got very wet and does not work , washing machine.
Larry, If you have washed your phone too, then it may have short circuited and burnt itself off. For a few minutes it may have survived the short circuit by expecting it to survive the whole wash cycle is asking for the moon. Anyway, After removing the battery, use your hair dryer on it without the heat for a long time so that all traces of water are dried up. Then reinsert the battery and cross your finger before you power it on.
Nov 09, 2009 | Motorola Cell Phones
Upper righthand corner, blue full moon, 1 cm in size. (solid blue circle)
The LCD in your phone got damaged and so try to replace the LCD in the authorized service station.
Jul 25, 2009 | Samsung SGH-t819 Cellular Phone
Water damage
I'm afraid you are out of luck. I've never had any luck (personally) when a cell phone got wet. However, I wouldn't throw the towel in just yet. Try leaving it in the window in the warm sun to dry out. I would remove the battery though.
Feb 22, 2008 | Cell Phones
When my screen got wet, I took it to Verizon. If your water indicater doesn't show any water damage they will give you a free phone no charge.
The water indicater is located underneath the battery, Pop the battery off and if the little circle is red there is no water damage.
Hope this helps.
Nov 30, 2007 | LG enV VX9900 Cellular Phone
Motorola Mobility RAZR V3 Logo
46 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
