Question about Refrigerators
Water or ice will not despense out of the door. However, the ice maker is making ice. The model nomber is BSS25JSRFSS, serial #VH228524
  • hottshot24 Mar 28, 2009
    Ice dispenses fine, but water will not dispense. The problem is in the tube lead through the freezer door for me. The rest of the tubing is fine. There is a connector in the bottom of the refrigerator. When I disconnect it and press the dispensing lever, the water flows out of the tube coming from the water filter. But, when I connect the tubes together again: No water dispenses.
  • 330 Answers
Check the water filter see maybe you need a new one.
Posted on Jul 05, 2008
Not despensing ice
Make sure the ice bin is pushed all the way in position. Also make sure you don't have a big clump of frozen ice blocking the auger and keeping it from working.
It is a good idea once in a while to take the ice bin out and completely wash and clean it out real good.
Jul 20, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Hi,I have a GE 42" Monogram refrigerator,model # ZISW42DYB,serial #LS037072. The problem that I have is the freezer is leaking water even if I turn the ice maker off.In a day or two the ice tray fills with...
Good day Paul.
Sounds like your diagnosis is right on. In extremely rare cases the ice maker itself could be at fault. But once again is extremely rare.
Dec 12, 2009 | Refrigerators
Nov 09, 2009 | GE Refrigerators
Ice maker is not making ice, yet the red light that indicates the ice maker is "ON" is flashing..
KitchenAid KSGR25FTSSOO side by side one day just quit making ice. We have blown out the lines and replaced the filter. The red light does blick when we open the door. The water despenser as a flow of water that is real slow. How and what do we do next?
Oct 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
Whirlpool Ice maker4 issue
Sounds like the optics are bad part # 4389102 this model(if we have the right model#)has two optics boards one receiver one emitter on either side of the door opening which shoot a beam from one to the other through the opening in each side of the bin,as long as nothing blocks that beam and the freezer is cold enough to chill the thermostat to temp in the icemaker,then it should be dumping ice.
Sep 13, 2009 | Whirlpool GS6NBEXR Side by Side...
The door ice despenser is not working. It makes
Make sure that the bucket is pushed in all the way. If the motor is running the screw should be turning. I would also take the bucket out and try to turn the auger by hand to make sure it is turning free.
Please rate solution if helpful. Thanks
Aug 19, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
Icemaker makes ice but wan't despense, also water wan't despense
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Jul 16, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
No Ice is being made. Water is being despensed at the door but it seems that no water is going to the ice maker. Have good water flow to the pump.
Is the ice maker turned on?  The on/off switch is located on the top right side of the freezer compartment.  The manual says that there is a sensor beam that passes from one freezer wall to the other to shut off ice making when the bin is full.  Check to make sure nothing Is blocking that signal beam and that the bin is correctly installed.
May 30, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
Refrigerators Logo
162 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
