Question about Pitco Frialator SG14 Deep Fryer
Pitco gas fryer. wont send the oil out.... - Pitco Frialator SG14 Deep Fryer
THE PUMP IS BAD OR IT IS CLOGGED AND NEEDS TO BE TAKEN APART.I HOPE THIS HELPS .CUS I REALY DONT UNDERSTAND THE QUESTION ALL THAT WELL,QUESTION NEEDS MORE EXPLANATION.
Posted on Oct 03, 2008
2 Suggested Answers
kebah
  • 684 Answers
SOURCE: 13 year old pitco frialator fryer pilot wont stay
Hi there.
Check and tighten all wiring connections.
Check the hi limit for continuity across the terminals using an ohm meter, if it has no continuity, you have to replace the hi limit.
Regards.
Posted on Aug 28, 2011
Pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Sep 12, 2011 | Pitco Frialator SG14 Deep Fryer
13 year old pitco frialator fryer pilot wont stay on. changed gas valve and thermopile.... pilot light wont stay lite
Hi there.
Regards.
Aug 21, 2011 | Pitco Frialator 35CS Deep Fryer
Can i disconect the hi limit switch and still use fryer
Hi there.
Hi limit switch/ device on fryers acts as safety device. It cuts gas supply on burners when it is triggered by high oil temperature in case the temperature regulating device failed to avoid further damage on equipment, property or life.
It is not advisable to operate the equipment with bypassed hi limit device.
I suggest to have it replaced first before putting the fryer back in operation.
For parts inquiry/ ordering, you can visit http://www.pitco.com
Regards.
May 29, 2011 | Pitco Frialator 35CS Deep Fryer
I have a Pitco Frialator 35CS Deep fryer that is leaking natural gas leak inside gas fryer door just above gas valve assembly the leak is bubbling through each of the 3 flues above the gas valve any help...
Opening fryer door during operation does not correct gas leak problem.
If there is gas leak on your fryer's system, you have to fix the leak or replace parts if necessary.
You can download parts, operation and owner's manual at pitco web on http://www.middleby.com
Regards.
Jan 16, 2011 | Pitco Frialator 35CS Deep Fryer
My pitco frialator fryer's pilate wont stay lit
Check the thermopile, it should be free of soot or any form of dirt. Pilot flame quality must be good. Gas pressure should meet the requirement as stated on the nameplate.
Oct 22, 2010 | Pitco Frialator 35C Deep Fryer
Pitco fryer
Try removing the oil and boil out the fry tank.
Fryer cleaning manual is downloadable on PITCO site at http://www.middleby.com
Jul 19, 2010 | Pitco Frialator SG14 Deep Fryer
My pitco gas frialator oil leak in tank .how can
You need to identify where the leak is coming.
If the leak is on the fry tank, best way to address it is to replace the oil tank.
Check the serial number of the unit with leak on fry tank, verify if it is still under warranty at PITCO web on http://www.middleby.com.
Jul 11, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco-matic filter system always getting clogged and won't return grease to fryer
Make sure that the filter system is correctly assembled so that oil impurities wont enter pipes and clog the system.
Apr 14, 2010 | Pitco Frialator SG14 Deep Fryer
Frilator pilot will light but fryer wont fire up
The thermocouple or thermopile is your culprit. If it is not sending the correct millivolt signal to the main part of the gas valve telling it to open then, the burners will not light. This is the cheapest part to start with. If after changing this out & you have the same problem then, you have a bad gas valve.
Jun 28, 2009 | Pitco Frialator SG14 Deep Fryer
35C+ Pitco Frialator overheats oil what is likely problem
I am having the same exact problem and I am assuming either the tstat or high limit units have failed.....
Jun 04, 2009 | Pitco Frialator 35C Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
239 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
