Question about Philips Magnavox 51MP392H Rear Projection Television
Philips 51 rear projection
I have a big screen tv and it was been a good one but it just started cutting off after about 30 minutes of play. it is like it is getting hot and cutting off.
  • Philips Master
  • 5,568 Answers
Your assessment of heating causing the problem is likely correct.
Check to see if the cooling fan is running. It almost certainly has one.
If the fan is functional, then the probable culprit is the power supply itself if no video or audio problems have shown up.
This may or may not be a separate, replaceable board.
Posted on Jul 05, 2008
  • Philips Master
  • 8,617 Answers
Thats a common problem with the DPTV300 through 355 chassis. You will either need to call in a repair tech for that type of troubleshooting, or replace the LSB circuit board ( Large Signal Board). You can get a replacement LSB circuit board at the following link for about half the price of what they actually cost. Here the link.
http://servicemanuals.vstore.ca/
I have a philips big screen tv that has double color around edge. iI was informed it was convergence integrated circuit were is that located on the set
It is located internally and can be identfied by looking for the large heatsinks (aluminium) the ICs (two of them) would be labelled STK...
Sep 18, 2009 | Philips Magnavox 60PP9701 60" Rear...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Philips big screen projection tv
sounds like the Convergence ICs are getting ready to go. Does it appear as a outline almost 3D? If so its convergence if its more like a glowing halo its coolant in the blue CRT that needs changing.
Jun 20, 2008 | Philips 51PW9363 51" Rear Projection...
Mute and C on the screen
The TV is in factory or demo mode - turn tv off and unplug it from wall outlet for 30 seconds - turn tv back on after 30 seconds and see if problem goes away. If not, press the (volume -) and (channel -) buttons repeatedly for about 10 seconds to see if "C" will go away. If this fails call 1-888-PHILIPS for further assistance (they do Magnavox also).
May 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
Picture is dim and blurry
The screen probably needs to be degaussed, which will require either a degausser or a technician. Try turning the television off, and then unplugging it from the wall outlet. Then replug after 30 seconds and turn it back on. Also, try plugging any cables from a cable or satellite box into another set of in-ports on the back. If the problem persists, the screen needs to be degaussed.
Feb 22, 2008 | Philips 51PW9303 51" Rear Projection...
Philips 51pw9303 screen hazy and has very little contrast
the fluid in the crt lens has become contaminated and discolored..the fluid can be removed and the bacteria build up can be cleaned,, the fluid will cost between 20 and 35 a bottle and you will nedd 2-3 bottles,,if you are not careful you can damage the set so it might be a good idea to have a tech do the job
Nov 24, 2007 | Philips 51PW9303 51" Rear Projection...
Magnavox 51" TV Screen
take the broken piece to the hardware store and have a piece of plexiglass cut the same size. thats what we did and it worked really well.
Jan 31, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
